GEN 3: Suspension set-up - Kawasaki ZX-10R.net
post #1 of 2 Old 09-15-2015, 02:50 PM Thread Starter
Hi, I ohlins TTX rear schock and front fork valve rebuild by Ohlins. I find some set-up data from racetrack rider with the same. My weight is 90 kg (198 lb) with gear. Front spring 10. Rear spring 90 Nm. First time ride with 100 Nm spring (recommended for racetrack for ma weight by my dealer), but too hard. Now is 90 Nm. Now its comparatively good, but it's not ideal. You can write specific settings which are used? Thanks.
siws is offline
post #2 of 2 Old 09-15-2015, 03:56 PM Thread Starter
Front and rear SAG - 27mm
rear compression 12 (stock)
rear rebound 12 (stock)
front compression 5
front rebound 12
siws is offline
Need Suspension set up for gen 3 zx10 w/240 lb rider zx10Rider34 Suspension and Tire Tech 2 09-14-2012 09:05 AM
3rd gen suspension set-up Fred-R Performance and Tech 4 08-10-2010 11:04 PM
Suspension set up on ZX-14 lyodbraun Pictures and Videos 0 06-24-2009 10:21 PM
05 suspension set up 1litereater Performance and Tech 6 04-25-2007 02:08 AM
Suspension Set Up hangman39 Performance and Tech 14 04-02-2007 07:44 PM
