gen 3: set sag now rear of bike is lower - Kawasaki ZX-10R.net
post #1 of 5 Old 06-16-2013, 09:42 PM Thread Starter
So I just set the sag on my bike. I had replaced the oem spring with a 10.7kg spring from race tech. I have the sag set to 35mm. The bike rides and handles so much better. Now I stand flat footed though. I know having the ass of the bike higher up again will help with turn-in. I was curious if anyone has tried the "jack up kits" before. Kinda like a lowering link but brings the bike up.
http://www.lustracing.co.uk/suspensi...k-up-kits.html
drifthunter is offline
post #2 of 5 Old 06-16-2013, 11:46 PM
moshpete's Avatar
rear ride height affects squat on acceleration a d having the rear high steepens the rake angle and trail numbers. you can just stack washers on the top of the shock mount to frame to add height. ive never seen a jack up kit used so i cant say anything on that
moshpete is offline
post #3 of 5 Old 06-17-2013, 12:17 AM
Crescent1101's Avatar
Did you get the 1/2 spacer from Racetech that goes with the shock?
2009 R6 Racebike - Up for sale!!! Let me know if interested.
2013 ZX10R- SOLD
2008 ZX10R- SOLD
Crescent1101 is offline
post #4 of 5 Old 06-17-2013, 08:33 AM Thread Starter
Ya, had to go get a spring compressor to get it in but figured there was a reason they recommend it.
post #5 of 5 Old 08-18-2013, 09:45 PM
Take a stock shock shim (AKA a thick alloy washer that is between the shock mount and frame on lots of zx6rs 06 and up). Just put it between the shock mount and frame. Just one will jack up your bikes rear end and help it turn a lot but will also make the zx10 shake its head even more.
badkawi is offline
rear set for gen 2 mrkidd Wanted: Buy or Trade 0 01-14-2013 10:20 PM
Wanted: Gen 1 rear set SILKIE SMOOTHE Wanted: Buy or Trade 5 11-19-2011 06:28 AM
rear sag sweetride10r Performance and Tech 1 09-10-2007 06:55 PM
how to set sag alone ? Lucky10R Performance and Tech 8 10-11-2006 07:04 PM
Finally set up the sag... Ground Zero The ZX-10R 6 02-28-2005 08:05 AM
