gen 2 front end. - Kawasaki ZX-10R.net
post #1 of 5 Old 06-01-2013, 02:52 AM Thread Starter
Cloud 9's Avatar
gen 2 front end.
i'm up for new front end on the gen 2 track bike .
what other model forks fit in the tripple trees?
are the later modles the same size tubes?
if they are would prefer to go later modle as the spring rates are better suited to my weight on later models
Cloud 9 is offline
post #2 of 5 Old 06-01-2013, 06:01 AM
I know for a fact that mine 06 has a 08 complete front end (forks, rotors, calipers and fender). I learned that when I wanted to replace the brake pads and the new ones didn't fit. At some point the previous owner replaced it.
Sent from Motorcycle.com App
Murquiza is offline
post #3 of 5 Old 06-01-2013, 10:21 AM
Gunny's Avatar
He probably just did a caliper swap..
Gunny is offline
post #4 of 5 Old 06-01-2013, 10:21 AM
Gunny's Avatar
I think gen 3's are longer than Gen 2's but the same diameter
Gunny is offline
post #5 of 5 Old 06-03-2013, 07:29 AM
I have the KYB forks, 08 calipers and 310mn rotors and 08 front fender on my 06 ZX10R.
I tried to find if there's any length difference and if the bike geometry was altered somehow but couldn't find the information. On the service manual the 08 vs 06 uses 8ml more of oil, the oil level is 3mm higher and the fork spring is 0.2mm larger.
Murquiza is offline
Gen 4 Front End Vibration Proteus The ZX-10R 32 08-28-2012 08:26 AM
Gen 4: Front End Torque Values Proteus The ZX-10R 12 08-21-2012 10:19 PM
Gen 4: Front End Vibration and Clutch Freeplay Proteus The ZX-10R 10 07-18-2012 02:54 PM
first gen front end install help kuziken10r Performance and Tech 11 08-07-2010 02:54 AM
WTB- front tire hugger, RAM AIR, FRONT END swing lo Wanted: Buy or Trade 2 07-10-2007 08:30 AM
