Gen 1: Tire size - Kawasaki ZX-10R.net
post #1 of 7 Old 06-15-2012, 09:15 PM Thread Starter
ninja3030's Avatar
Gen 1: Tire size
I'm sure it is covered somewhere, but can't find with many search!
I have a generation 1, and currently use Pirelli slicks in 190/55. Right now I can't have this size for a few weeks. I want to know if a 190/60 or a 200/55 will fit (chain and swingarm). I'm not able to find specifications on them. Even with -1 in front sprockt, I'm afraid of swingarm clearance.
________
Yan
'04 Orange ZX-10R
Hindle high-mount slip-on, Muzzy thin head gasket, PC III USB, BMC race filter, Hyperpro RSC damper, front flush mounts, rear fender eliminator, Champ's frame sliders, Michelin Pilot Power, Sylvania SilverStars, PIAA H-222, Teknic Violator one piece, Alpinestars S-MX, Shoei RF-900.
ninja3030 is offline
post #2 of 7 Old 06-15-2012, 10:02 PM
Btrain87's Avatar
when i bought my bike it had a 200/55 on it. 190/60 should work as well but you will need to get custom screws and spacers for the tire huger since it will be that much higher.
Btrain87 is offline
post #3 of 7 Old 06-15-2012, 10:05 PM
mreyna75's Avatar
i ran a 190/60 race takeoff on my gen 1 and the slag(i guess you would call the pieces of rubber picked up off the track) rubbed the tire hugger till i burnt it off
mreyna75 is offline
post #4 of 7 Old 06-15-2012, 10:12 PM Thread Starter
ninja3030's Avatar
My hugger was already rubbing with 190/55, so it is removed right now.
________
Yan
'04 Orange ZX-10R
post #5 of 7 Old 06-15-2012, 11:41 PM
GreenWeenie's Avatar
190/55 is a bit smaller than the 200/55 and 190/60 which are all "about" the same size...
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
post #6 of 7 Old 06-16-2012, 12:44 AM
Btrain87's Avatar
not a good idea. i run a 190/55 now too. all you have to do is bring the tire hugger screws to your local hardware store and ask for it in a longer length. you're looking at 50 cents a screw then get 5mm spacers another dollar at most! its worth it. the tire huger is there for a reason. just think about what the bottom of the tail looks like after a burn out! i bet your shooting rocks at your self!
Btrain87 is offline
post #7 of 7 Old 06-16-2012, 09:34 AM
or10r's Avatar
Actually I put a wedge between my hugger and tire an heated the hugger up really hot with a hair dryer then let it cool and took out the wedge and wa-la, no rubbing.
or10r is offline
tire size busaisbetter The ZX-10R 12 05-30-2012 08:02 PM
Tire size? salszx10r General Motorcycle Discussions 3 06-18-2010 07:38 AM
Tire Size kiloalpha Performance and Tech 19 03-27-2008 12:56 PM
Tire size superman10r Performance and Tech 12 12-04-2007 08:11 PM
tire size ? mylegacy412 The ZX-10R 17 07-28-2007 12:29 PM
