Gen 1 stock front suspension too hard - Kawasaki ZX-10R.net
post #1 of 14 Old 08-30-2014, 05:51 AM Thread Starter
Even with compression turned right out, it still feels hard. I have just replaced seals and fresh oil but made no difference. Without spending too much, is there anything I can do?
millsy is offline
post #2 of 14 Old 08-30-2014, 07:59 AM
horsePOOGAS's Avatar
How many "clicks" do you have from right to left? count them, you should only have about 10 esh. (service manual recommends "9th" click for a 150lb rider...) If you don't then it's possible you didn't get your piston rod nut adjusted properly when putting it back together.
horsePOOGAS is offline
post #3 of 14 Old 08-30-2014, 12:49 PM Thread Starter
I had a local mechanic do the seals, new oil. It was hard before I even had that done. I have tried various levels of compression, but makes minimal difference.
millsy is offline
post #4 of 14 Old 08-30-2014, 02:15 PM
or10r's Avatar
Ohlins fork springs are about 100 bucks. Thats not bad if you can install them yourself.
or10r is offline
post #5 of 14 Old 08-30-2014, 06:54 PM
TechX's Avatar
The Gen 1 has harsh oem forks when It was stock I would run 0 compression in the front when it was stock. This was for track day use and I weighed about 245 in leather's then. The best way to fix it is like (or10r) said Ohlin spring's. I did mine with Race Tech stuff and the difference was amazing much better feedback and feel. More compliant and smoother function. Harshness was eliminated.
TechX is offline
post #6 of 14 Old 08-31-2014, 11:44 AM Thread Starter
Thanks, just looking on their website to see what type I would need...
millsy is offline
post #7 of 14 Old 08-31-2014, 01:38 PM
Kawasaki Whisperer
MrMoto73's Avatar
Send a message via MSN to MrMoto73
Check out GP suspension. I sent my forks to them for a refit and every 3 or 4 years I send them in for service. Basically tell them how you ride and what you want and your golden. Think I spent $300 hundred for the refit, all new internals etc... they can put Ohlins internals in your stock tubes as well. Pretty sure other places out there that do the same but I have never had a reason to look elsewhere as they provide excellent service.
http://www.gpsuspension.com/services/
MrMoto73 is offline
post #8 of 14 Old 09-01-2014, 06:40 AM Thread Starter
Thanks.
Is it easy to pull some oil from the forks to see if that helps?
millsy is offline
post #9 of 14 Old 09-02-2014, 02:36 AM
milo5171's Avatar
Images: 9
when you say compression turned right out do you mean preload?turned right out,or are you talking compression damping?
milo5171 is offline
post #10 of 14 Old 09-02-2014, 05:15 AM Thread Starter
Yes I mean compression damping. I thought preload is just the spring height?
millsy is offline
ISO gen:1 base track setup for 160# rider, and stock suspension. B4MechGuy Suspension and Tire Tech 0 05-07-2014 06:36 PM
For Sale: Gen 2 & Gen 3 Stock Front Wheel Rim 1fast10r619 Parts, Gear and Accessories 3 11-01-2012 09:33 AM
Gen 1: Looking for the best front and rear suspension setup zx10rracer83 The ZX-10R 2 09-21-2012 10:44 PM
Info on stock suspension Gen 1 OxyG3nE Suspension and Tire Tech 28 06-19-2012 04:27 AM
Wanted: Gen 3 stock front footpegs superj Wanted: Buy or Trade 10 08-19-2011 08:40 PM
