Gen 1 Bent frame handling info - Kawasaki ZX-10R.net
post #1 of 3 Old 06-24-2016, 04:11 AM Thread Starter
Hey,
As well known the Gen1 frames are nutoriously known for cracking frames, so not knowingly (back in the day, didn't have much knowledge) bought a bit of a lemon with welded frame and recently found new cracks on the other side.
Facts : The frame is cracked and will need welding, it's also slightly bent and pulls to one side.
My question is: Is there any tricks to even out the handling a bit? Unfortunately there will be no way to straighten it here where i live so i'm left with what i have.
On a side note, the turn in is crazy slow on the bike even with pirelli 55 wall tires (diablo supercorsa bsb). If id slip forks a bit lower trough yokes, that should speed up the turn in right? (aahh ofc, the bike has GSxr 1000 forks).
the13thangel is offline
post #2 of 3 Old 06-24-2016, 07:55 AM
SkyDork's Avatar
Frankly, riding around with a bent frame is dangerous. The handling can and will be unpredictable and can be prone to more bending. Welding it multiple times over and over can weaken it even further. Unless you put it on a jig to hold it solid straighten it out before welding, then you have no basis for knowing how it will perform in the end. If you can't get it professionally aligned where you're at, then you should be SERIOUSLY considering a new frame to replace it. I would not ride a bike with a bent frame. No bueno.
Turn-in is a compromise between stable and unstable conditions. If a bike a bike is stable, it wants to resist direction changes. Likewise, a quick handling bike is usually twitchy and not stable and wants to change directions on it's own. It's a fine line to try and find the point in between these two things that gets you decent stability and quick handling.
Since you already have taller tires on the rear is increasing the rake and quickening the turn-in. Dropping the forks more will have the same affect. Go too far and you'll have an unstable bike that will headshake and tank-slap. I believe your problems with turn-in are related to your bent frame. Farting around with the geometry of the suspension to try and make up for a frame that isn't lined up is not going to do anything for you. It's dangerous.
#WordCrimes
SkyDork is offline
post #3 of 3 Old 06-26-2016, 06:14 AM Thread Starter
Hey, thanx for the reply!
I do agree to you that it's dangerous, but the options round here are slim. Ive done track days and done bout 15k km, it doesnt do much unpredictable stuff and its not crazy out of the line. See unfortunately options are slim: New fram = insane $$$$, used good = cant find, Gen1 frames are very well know for braking so all of them are already broken. Scrapyard or so - no such places here. Ebay - everythings already broken. Jig and pro alining and welding - not available here. So unfortunately it is what it is. I know, pretty sad.
Have you heard anything bout Gen1 frame replaced with Gen2?
Gen 4 handling issue ukzx10r Suspension and Tire Tech 21 05-30-2016 04:16 PM
Handling on the gen 4! Turbodc2 The ZX-10R 20 08-09-2013 11:24 AM
Gen 1 handling issues are solved. OmegaX The ZX-10R 32 10-04-2009 03:35 PM
Gen 1 Handling? Ninja187 The ZX-10R 11 12-17-2007 09:36 PM
Bent frame from sliders west The ZX-10R 13 08-12-2006 11:21 AM
