Front tire size - pro and cons? - Kawasaki ZX-10R.net
post #1 of 7 Old 09-14-2012, 10:05 PM Thread Starter
Just curious as to the pros and cons of the 60 vs 70 on the front tire size.
I would imagine the 70 turns easier but is there any drawbacks or benefits otherwise of one over the other?
Gonna be running the michelin power one on a 2g 10R and I am a big guy at 6'2", 280lb so any advice would be appreciated.
jettaglx91 is offline
post #2 of 7 Old 09-15-2012, 08:37 AM
filthy phil's Avatar
The shorter tire turns faster.
I had a vfr1k with 16" wheel, fkn insane handling.17 is more stable
team FTP
Area p, zx14 nissins and mc
Riflemans 1/5. -1 +1 sprockets w/chrome ek zzz. galfer lines. K&n.,ultra custom black front fender // over 55k miles
filthy phil is offline
post #3 of 7 Old 09-15-2012, 09:11 AM
RPG76's Avatar
The smaller section will give you faster turn in. But the decreased radius means you are losing some rubber when the tire is leaned over. There is a reason most bike come with the 120/70.
05 ZX10r "the Mongrel": GP Suspension rebuilt forks, LE Penske double shock, 05-06 ZX6rr shock linkage, Brembo RCS MC, Nissin calipers (best mod for this bike!!!), Attack rearsets, Motion Pro Revolver throttle kit, ASV clutch lever, Champs sliders, smoked Zero Grav DB, Ti caliper bolts, CF fender, Renthal grips, Speedo healer, Maviryk MDA123 batt, Supersprox +3 520, That's it..... For now
190/55>190/50
RPG76 is offline
post #4 of 7 Old 09-15-2012, 09:59 AM Thread Starter
I'm not change wheel size just curious on tire.
I figure the less inertia itself of a 16" vs 17" wheel alone makes a huge difference.
But as far as tire size which would u recommend for aggressive road use for a big guy
post #5 of 7 Old 09-15-2012, 10:01 AM Thread Starter
Would the less radius of the 60 allow for more braking power in a straight line? I would assume when upright the 60 has more road contact?
post #6 of 7 Old 09-15-2012, 10:05 AM
Leave it as is. Find something else to change on that gen2, like the brakes, if you aint already
team FTP
post #7 of 7 Old 09-15-2012, 11:42 AM Thread Starter
Brakes are already done
Gen 1: Tire size ninja3030 Suspension and Tire Tech 6 06-16-2012 09:34 AM
tire size busaisbetter The ZX-10R 12 05-30-2012 08:02 PM
180 over 190 size tire..pro/cons? TexasRider Performance and Tech 11 03-27-2012 11:46 PM
tire size 180 vs 190 jm981_4343 The ZX-10R 7 05-23-2011 07:09 PM
Tire size superman10r Performance and Tech 12 12-04-2007 08:11 PM
