Fork rebuild suggestions.??? - Kawasaki ZX-10R.net
post #1 of 2 Old 05-06-2013, 11:36 AM Thread Starter
I popped a seal this weekend so I figure while I'm I. There I should address the internals..I'm 200 lb in gear should I do springs and a revalve kit from race tech? I just spoke with them and they Said the stock springs are fine for my weight. I've Been told in the past that the stock springs are too long.... Idk what to donor which direction to go in. Also is the gen 3 shock an upgrade over then horrible gen 1?
inginekilla is offline
post #2 of 2 Old 05-20-2013, 08:07 PM
If i were you better to keep it stock or if you have extra get a aftermarket forks.
kartl is offline
Gen 3: engine rebuild suggestions greenman43 Performance and Tech 0 08-30-2012 05:01 AM
Fork rebuild issues, suspension guru's HELP!! flthy1 Performance and Tech 20 07-21-2010 01:52 AM
What all is needed for a Fork rebuild? ninjaturtle Performance and Tech 10 09-26-2008 08:28 PM
Fork revalve suggestions? mrdo24 Performance and Tech 1 12-16-2007 11:04 AM
Fork Rebuild 05Ti10 Performance and Tech 20 07-20-2006 10:25 AM
