fork oil capacity gen 1 - Kawasaki ZX-10R.net
post #1 of 4 Old 09-02-2012, 09:36 AM Thread Starter
hi guys just a quick question and wondering whats the oil capacity per leg.
been told 490ml or 590ml just unsure which is right
thanks
seddo is offline
post #2 of 4 Old 09-02-2012, 11:16 AM
download a manual from this site.
capacity depends on how much of the fork you are disassembling ( i.e. - changing oil vs changing seals would call for different amounts of oil)
mityaz is offline
post #3 of 4 Old 09-02-2012, 01:30 PM Thread Starter
i did have the manual but got wiped. its the fork seal replacement
seddo is offline
post #4 of 4 Old 09-02-2012, 07:33 PM
Does not drive into smoke
El Zilcho's Avatar
From the manual:
Amount per side:
  • When changing oil: approx. 490mL
  • After disassembly and completely dry: 576 +/- 4mL
In any case, measure the oil level as the distance from the oil surface to the top of the tube: should be 91mm (+/- 2mm).
El Zilcho is offline
fork oil capacity for my 04 zx10 mrlopez Performance and Tech 2 09-04-2010 09:46 PM
oil capacity pan4905 The ZX-10R 4 04-30-2009 12:07 AM
Oil Capacity????? OHFOUR10 Performance and Tech 5 01-10-2009 02:53 PM
fork oil capacity logmaster ZX-6R & ZX-6RR Archives 1 07-10-2008 02:59 PM
fork oil capacity Titte Performance and Tech 2 12-07-2007 12:11 AM
