Fork modifications - Gen 1 ZX10R - Kawasaki ZX-10R.net
 39Likes
post #1 of 49 Old 09-24-2018, 01:03 PM Thread Starter
whiteryno111's Avatar
Hi,
just took the 04 forks apart and can't locate anything resembling a shim stack/valve assembly,
it's a damper rod cartridge Kayaba, but it's difficult to find any good info out there about its
tunability. (why is that so?)
Sag is good, so the spring stays but the front end is really vague and lacking in feel not giving
any confidence entering corners.
I'm new to suspension tuning but wanted to start working and learning on my track bike.
Racetech sell a gold valve kit (compression) and that's probably the way to go, but still if I could
improve the stock stuff and save a bit... mhmmhmh...
what do the pros say?
Cheers
whiteryno111 is offline
post #2 of 49 Old 09-24-2018, 02:53 PM
LDH
LDH's Avatar
The pros say OEM fork pistons suck and aren't worth the time or effort to mess with. That is why 25 & 30 mm cartridges exist.
My memory ain't what it used to be, but I kinda remember those early Kawi rods were swedged making it difficult at best to get to the pistons.
whiteryno111 likes this.
LDH is offline
post #3 of 49 Old 09-24-2018, 07:05 PM Thread Starter
Right, thanks
So to get to the valves, can I just use a spanner on that cap? is it threaded?
post #4 of 49 Old 09-25-2018, 12:09 AM
I have Racetech valves in a couple of my bikes forks. They work great. I have owned Ohlins carts too, they also work great. Call Racetech. They are very helpful. Yes, I believe that part is threaded but you will find out soon enough once you try to turn it with a wrench. Use some penetrating oil on it. You can make a rod holding tool with a block of wood and a hole saw so you don't crease the tube.
The Prophet is offline
post #5 of 49 Old 09-25-2018, 06:24 AM Thread Starter
Thanks for chiming in,
How is the cylinder supposed to come out? Can't see any circlips...
Not very intuitive design and then the fear of damaging something.
all new to me!
Some more photos for documentation purposes.
ID:	419877   Click image for larger version
post #6 of 49 Old 09-25-2018, 11:13 AM Thread Starter
Ok,
compression valve removed, somehow the nut on the other end came loose and left the valve stuck in the tube.
It was just the rubber oring keeping it in place.
What do I do with it now?? :D scrap?
post #7 of 49 Old 09-25-2018, 11:46 AM
You should be able to gently pry o-ring with flathead while being careful not to scratch/damage fork tube.
wheelz96 is offline
post #8 of 49 Old 09-25-2018, 12:12 PM
evallarta1's Avatar
Do yourself a favor and get a book like Race Techs Motorcycle Suspension Bible. You're gonna go down a dangerous path and possibly get yourself hurt if you get something wrong. RTs book will go through theory and explanations and how to fully disassemble and assemble your forks.
As to piston kits the following will work.
Race Tech
Ohlins
K-tech
Bitubo
Penske
Any 20mm piston will fit.
rcannon likes this.
Velocity Calibrations
evallarta1 is offline
post #9 of 49 Old 09-25-2018, 11:54 PM
Race Tech
Ohlins
K-tech
Bitubo
Penske
Good advice, as there are nuts that need lock-tite etc. A Racetech goldvalve kit will give you the info and the parts necessary. Valving options come from the Racetech website.
CanyonCarver likes this.
post #10 of 49 Old 09-25-2018, 11:56 PM
That is your piston valve stuck down there inside the tube. It should have pulled out all together.
05 zx10r modifications circleracer Performance and Tech 2 06-29-2010 08:39 AM
Modifications for full exhaust system lespaul66 Performance and Tech 14 08-21-2006 01:43 PM
Winter modifications done lespaul66 The ZX-10R 7 04-27-2006 12:32 AM
Engine modifications. ninjazx10r The ZX-10R 6 06-01-2005 11:16 AM
What would be the best modifications for drag racing? CentBiker Strip 14 10-05-2004 02:35 AM
