Fork modifications - Gen 1 ZX10R - Page 2 - Kawasaki ZX-10R.net
 37Likes
post #11 of 45 Old 09-26-2018, 07:19 AM Thread Starter
whiteryno111's Avatar
As some have mentioned the factory stuff is not worth messing with so I already ordered a Andreani compression valve kit
supposedly a lot better design than stock.
Yeah I know, that little nut is so tight on that thread but by undoing the bottom cap it all came apart in there.
The piston valve was pretty tight in there too!
I just hope the new stuff gives a bit better feedback and feel what that tyre is doing.
Tyre wise the wear has been perfect so I figured I'd leave rebound alone for now.
whiteryno111 is online now
post #12 of 45 Old 09-26-2018, 10:16 AM
LDH
LDH's Avatar
It won't. At best, if everything is perfect with the kit you install (which I doubt as I am not impressed by anything Andreani comes up) you will get more compliance from the suspension components, but feel & feedback will always remain vague. Again that is why 25 & 30mm carts exist.
I have no idea what your correlation is between tire wear and rebound or why you think that leaving the rebound out of the equation and only focusing on Compression is going to help you in any way, shape, form or fashion, but good luck.
JayBoCC2 likes this.
LDH is offline
post #13 of 45 Old 09-26-2018, 11:06 AM
michael4012's Avatar
I'm one of those people who can't be told different when I know best, the trouble I have is sometimes I think I know best when in fact i don't, over my 54 years I have learned many things but the lessons which cost me dearly and the lessons that cost sooo much time are the ones that I just can't reach out with. I see this a lot on these forums, everything really everything, I see people throwing money and time away just because they can't pause to evaluate thoroughly, this can be many things, I'm using suspension as an example on this thread, people just can't take on board what "professionals" often give away for free, but also at the cost of there time. People will willing pay consultation fees to the pros, iv seen people write of bikes get hospitalised, & get them selves into debt in the bank, iv seen people sell there bikes just because they won't listen and fail to make it work. Please this guy LDH is a pro ...... listen to his teachings.
michael4012 is offline
post #14 of 45 Old 09-28-2018, 04:32 AM Thread Starter
I know what you guys are saying and I appreciate all the wisdom you are trying to empart here.
It's just that I'm also stubborn but humble as well and so I like to verify some things by myself not meaning any disrespect.
I bought the kit not hoping too much really, but if it gives me that extra bit of confidence on track it was worth it.
Also if I can make the forks a tad better without spending 1000eur (at least for any of the cheapest cartridge kits) that I
suspect at that price range won't make the world of a difference. (could be wrong though!)
LDH, what is the most effective and cheapest way to make these forks better?
please don't mention the 25 and 30mm carts again..?! just kidding :)
Thanks guys
post #15 of 45 Old 09-29-2018, 08:21 AM
Thanks guys
I have ridden all kinds of forks kits. Cartridges, Big Piston Aftermarket kits, stock stuff. I have a stock fork in my 2005 Zx6r and it has a revalved 20mm fork kit in it. Not sure which brand, but it works excellent. Check out Racetech, Paul Thede has been doing this Shit for decades. He does know what he is doing. I am sure he sells a piston valving kit for your fork. You get the valving specs with it. You can tweak the specs to fit your needs. The kits are relatively inexpensive. Don't believe the Hype. Most guys can't ride the bike hard enough to know if the fork is working well or not.
CanyonCarver and whiteryno111 like this.
The Prophet is offline
post #16 of 45 Old 09-29-2018, 08:59 PM
LDH
LDH's Avatar
Therein is the difference between what I do versus what many others do. I don't work to the lowest price point. I don't do things halfass and then hide behind the idea that it is ok because it was cheap. I don't specialise in making bikes mediocre, I make them fuckin awesome. That comes with a price.
LDH is offline
post #17 of 45 Old 09-29-2018, 10:16 PM
Bottoms-Up's Avatar
That's why half the time you come across as a pompous ass.
If rating fork performance on a 1 to 10 scale and stock
forks are a 1 and Ohlins are a 10
Reworking the stock forks with springs, re-valving, oil, etc. and
the general curiosity of trying to learn about set up and
shock performance leads to a mediocre rating of a 2,3 or 4 on
a scale of 1 to 10 that's still better then a 1 rating for people
that don't have the money to spend on a full Ohlins set up.
I don't think there's a misunderstanding on the point that
if one had the money they would swap for a Ohlins set up
so they could be fucking awesome too.
Bottoms-Up is offline
post #18 of 45 Old 10-01-2018, 07:33 AM Thread Starter
Things don't have to be all black and white, I like grey areas, and those are the fork mods and piston kits, and theres a
market for all that.
Most of the times, it's the rider that makes most difference on the bike at the track.
I know that some shops change the original stack and modify the stock valves (drill them out whatever)
and that made me curious as to what can be achieved vs. aftermarket valves.
I do all the work on my own bikes, just never messed with usd forks.
The objective here is to make the bike feel better and learn suspension tuning in the process.
But for now I'm going to try the andreani kit see how it feels and go from there.
Melampus likes this.
post #19 of 45 Old 10-04-2018, 04:38 AM
Melampus's Avatar
Talking
I'm loving this thread! I'm in a similar boat whereas I'm on a tight budget, and I want to use my Gen1 to learn more about suspension tuning. I've been watching as much of Dave Moss' free content as possible, and threads like this are really motivational!
Thank you for all the wisdom, and much more thanks for all the color commentary!
Embracing the silence amid a life & land full of static...
Melampus is offline
post #20 of 45 Old 10-04-2018, 01:40 PM
The PROS.....I use the term loosely, want you to think that you cannot make stock components work well. All of the Black Art of suspension adjustment and customization is schrouded in Mystery. Racetech has removed some of the veil of secrecy and taught some of the masses. This does not sit well with other suspension guys who are trying to make a buck. Oh well.
Capncalyx likes this.
05 zx10r modifications circleracer Performance and Tech 2 06-29-2010 08:39 AM
Modifications for full exhaust system lespaul66 Performance and Tech 14 08-21-2006 01:43 PM
Winter modifications done lespaul66 The ZX-10R 7 04-27-2006 12:32 AM
Engine modifications. ninjazx10r The ZX-10R 6 06-01-2005 11:16 AM
What would be the best modifications for drag racing? CentBiker Strip 14 10-05-2004 02:35 AM
