Fork alignment-twisted fork or tweaked bars - Kawasaki ZX-10R.net
post #1 of 23 Old 06-03-2014, 07:14 PM Thread Starter
Hey Guys-
have a bit of ocd kicking in on the steering of my gen 2.
my wife recently went to move the bike out of the way to park and she didn't have the kick stand down!! it tipped and luckily it hit the left handlebar at a 45 degree angle against the garage wall and not a full knock to the ground. But when it fell, it caught the left handlebar end and caused the bike to turn hard right
Anyway, when i have the bars square in my hands, the front tire is about (i'll use measurements rather than degrees)a 1/4" pointed to the right. no biggy as it tracks straight. For kicks i loosend the axle, pinch, and lower triples to do the "bouncing" method to see if it all realigned. Tighted all back up and still points to the right?
Possible the handlebar itself got tweaked when it caught?
i read on a thread that the fork tube could possible have twisted in the triple clamp. Does this mean that (sounding stupid here) the fork tube actually twisted within the triple clamp, or that the fork twisted the triple clamp itself? I beleive it is not the latter explination.
if i loosend all, say the left side from the pinch bolts to the upper triple clamps and twist within the clamps, does this have an effect on which way the wheel points?
sorry for the length, like i said OCD.
CTYrdr is offline
post #2 of 23 Old 06-03-2014, 08:34 PM
SkyDork's Avatar
More than likely the clip on is bent.
#WordCrimes
SkyDork is offline
post #3 of 23 Old 06-04-2014, 04:33 AM
or10r's Avatar
Or the clip on got banged over a bit on the fork.
or10r is offline
post #4 of 23 Old 06-05-2014, 01:20 PM Thread Starter
update
i ordered a new oem left bar, so hopefully that will do it. Both forks were aligned correctly, the axle bold slid in and out easily so i measured the bar ends to a fixed point and sure enough, they were off about 1/4" too much work to take both bars off and compare one to the other. When the new bar comes in, i'll compare then.
Also, just for kicks, i measured the rear wheel alignment and i was in the same boat as many others: the tick marks aren't exact. Wheel was pointed to the left, which may also have contributed to the compensation of steering to the right.....
CTYrdr is offline
post #5 of 23 Old 06-05-2014, 04:50 PM
The Pace
scout's Avatar
I can't image my wife trying to move my bike. The two simply don't connect. She would drive into it, though. That I'm sure. I think I would've loosened the left clip and tightened then checked. Hope the new one works.
scout is offline
post #6 of 23 Old 06-05-2014, 06:14 PM Thread Starter
Scout, my thoughts exactly on her moving it, but what do i do....anyway, i loosed, and retightened, the alignment screw underneath that mounts to the triple prevents adjusting, if i don't use that screw i can adjust it into a good position, but again this points to a tweaked bar, again can't be 100% until the bar comes in....thanks tho
CTYrdr is offline
post #7 of 23 Old 06-05-2014, 06:38 PM
or10r's Avatar
Yeah mine wont come within a three foot radius of mine for fear of her life.
or10r is offline
post #8 of 23 Old 06-12-2014, 06:54 PM Thread Starter
ok guys
i got the new left bar in and installed it, i wish it had worked but still the same, looks cleaner if that helps haha
i was searching and found this old thread that seems to be the answer to my prayers but the pix expired or something!!!
https://www.zx-10r.net/forum/showthread.php?t=78039
i sort of get the concept but how (trying to imagine) by loosening the clamps/ botls etc do i twist the forks in the tubes? am i right by thinking that i grab ahold of the gold fork tube and literally twist it within the triple clamp? by doing so will that alter the position of the direction the front wheel points?
looking at my bike from the top, i can see the top edge of the left side of the tree if you will, sits higher than the top right side of the triple trees. So that would tell me by somehow bringing the left side down/ back...that would align my wheel. Just not getting how twisting the fork tube accomplishes this?
i wish these pics would populate so i can see
any help??
CTYrdr is offline
post #9 of 23 Old 06-12-2014, 07:40 PM
SkyDork's Avatar
If you still have the issue, the top triple is likely twisted a bit compared to the bottom triple as you mention. Loosen all the clamping bolts around the top triple. Then stand in front of the bike with the front wheel tight between your legs. Pull the bars hard in the direction they need to go to straighten them out, check the alignment, tweak more as needed, and then tighten up everything.
#WordCrimes
SkyDork is offline
post #10 of 23 Old 06-12-2014, 10:43 PM
Dragone's Avatar
Images: 11
If you have a stem lift, I will keep the triple clamps just tight enough that you can relax the forks. Verify the fork height, clamp them to spec.
W.F.O.ing with style will bring life back into focus
Dragone is offline
Another fork seal ? kawdawg Suspension and Tire Tech 13 06-27-2012 10:20 AM
Gen 2: Fork seal change/fork oil.......again. Lycanthrope Performance and Tech 3 05-11-2011 03:34 PM
FS: Ohlins Fork Tool and Fork Oil green_zx Parts, Gear and Accessories 1 06-23-2010 02:33 PM
Fork Seals: Help with Removing Fork Cap ('05 ZX-10R) Henry The ZX-10R 3 08-16-2009 10:40 PM
Fork You! Hoser Performance and Tech 37 05-04-2007 01:56 PM
