Flipping the axle - Kawasaki ZX-10R.net
post #1 of 14 Old 06-27-2014, 06:16 PM Thread Starter
Chriscm922's Avatar
Flipping the axle
Is it possible to flip the rear axle on a gen 4? I was messing with it today, and couldn't seem to get it. It looks like the axle could possibly be smaller on the left side. Just curious if anybody has done this, and is it possible?
Chriscm922 is offline
post #2 of 14 Old 06-27-2014, 08:41 PM
Tech5's Avatar
Engineers made all them one way , I would leave it alone ....
The Truth
Tech5 is offline
post #3 of 14 Old 06-27-2014, 10:21 PM
GILBY's Avatar
I've always flipped mine so the nut is on the right side. I find it easier to get everything lined up when coming in from the left side. And the wheel doesn't step out when torquing the nut down - it just pushes against the alignment bolt and stays right where you set it.
This was a trick I picked up on the 6r forums from an old road racer. I've never had any ill effects from running it this way, my best guess would be that if the bearings ceased to the axle somehow, forward rotation on the wheel could potentially spin the axle and loosen the nut? The same scenario on the left side would just spin/tighten the nut and lock the wheel. But hey, I'm not an engineer so maybe there's some other reason they do this.
-2012 ZX10R-
-Ohlins TTX EC Shock -Archer's ECU Flash -Dunlop Q3's - Vortex -1/+2 - Rifleman 1/5th Throttle Mod - KLEEN AIR Mod - Woodcraft Sliders/Spools - PUIG Z-Screen - StompGrips
GILBY is offline
post #4 of 14 Old 06-27-2014, 11:45 PM
Bottoms-Up's Avatar
I'm on a Gen 2, so not sure about a Gen 4, but I've always flip mine
as well, nut to right side on all my bikes (if it wasn't already).
Bottoms-Up is offline
post #5 of 14 Old 06-28-2014, 06:06 AM Thread Starter
Chriscm922's Avatar
Yeah, that's the reason I want to flip. It slides through fine from the right, but not the left. So I wasn't sure anybody has any tricks for it.
post #6 of 14 Old 06-28-2014, 09:59 AM
GILBY's Avatar
Try putting the bike on a rear stand, and putting a couple wood blocks under the tires so it only drops a tiny bit. This will help you get used to getting it through that side. You can also get it halfway through and let go of the wheel, the axle will support the weight of the wheel while you line up the caliper carrier.
-2012 ZX10R-
GILBY is offline
post #7 of 14 Old 06-28-2014, 10:57 AM
Tech5's Avatar
I use my left foot to hold it and left hand wiggle the tire and right hand sticking the axle in
Never issue takes 2 mins when you know what you're doing
The Truth
Tech5 is offline
post #8 of 14 Old 06-28-2014, 12:24 PM Thread Starter
Chriscm922's Avatar
It's not an issue going through the right side, it's an issue going through the left side. Which is why I asked the question.
post #9 of 14 Old 06-28-2014, 12:25 PM Thread Starter
Chriscm922's Avatar
Yeah, that's what I was doing. For whatever reason through the left, it just won't go. So I didn't want to essentially force it of there was a difference in the axle.
post #10 of 14 Old 06-28-2014, 06:01 PM
Tech5's Avatar
Gen4 ?
My bike axle stock goes thru right side
What bike we talking about ?
The Truth
Tech5 is offline
Flipping the Bars (Clip-Ons) renais The ZX-10R 1 04-02-2013 07:17 AM
wtb rear axle spacers and axle nut for 08 blaze00 Wanted: Buy or Trade 0 08-27-2010 10:22 PM
Axle and spacers kwakman Wanted: Buy or Trade 1 10-10-2006 06:32 PM
ISO a pic of the guy on bike flipping... off camera? avdigigeek The Out House 13 07-08-2006 02:41 PM
Flipping people off sonnyboy11 The Out House 35 05-11-2006 09:03 PM
