Factory defective tire? - Kawasaki ZX-10R.net
post #1 of 11 Old 03-04-2015, 04:54 PM Thread Starter
Formerly "bms"
BrandonZX10R's Avatar
So I put my Dunlop Q3's on about a week ago and noticed small wobble in the front end cruising between 35-60 mph. I've balanced the tires twice. Deflated and spun the rim around the tire. Checked every thing to make sure its right. It took 40 grams worth of weights to balance it out. The tire had a real heavy spot on one end. I was just wondering if you guys have had a defective tire in the past and caused your bikes handle bars to wobble and if putting a new one on fixed your problem.
BrandonZX10R is offline
post #2 of 11 Old 03-04-2015, 05:14 PM
LDH
LDH's Avatar
I've seen this many times over the years. Almost always with Dunlops, once or twice with a Bridgestone.
LDH is online now
post #3 of 11 Old 03-04-2015, 08:53 PM
Teeks's Avatar
i have certainly seen it with cars, not so much with bikes. I am sure it is more than possible though.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #4 of 11 Old 03-04-2015, 09:01 PM
blink.'s Avatar
Yes, I had a q3 rear tire split the tread from the left to the right.
There is also a guy in my area that all he sells is defective tires, (he doesn't tell you that) but he sells new front tires for $25 and new rears for $50..not sure how he gets them but I've seen a truck load of them get delivered to him.
blink. is offline
post #5 of 11 Old 03-04-2015, 09:15 PM
The Pace
scout's Avatar
idk, something not right. I gone thru a bunch of q3s and some q2's and no probs.
scout is offline
post #6 of 11 Old 03-04-2015, 09:25 PM Thread Starter
Formerly "bms"
You're not talking about Don are you?
post #7 of 11 Old 03-05-2015, 12:50 AM
blink.'s Avatar
I don't know his real name, only by a nickname everyone calls him it's "push"
blink. is offline
post #8 of 11 Old 03-05-2015, 06:44 AM Thread Starter
Formerly "bms"
Hmm must be a few around here like that then.
post #9 of 11 Old 03-05-2015, 08:36 AM
esir_spd's Avatar
I did not have the same issue as you but I did receive a factory defect Q3. There was a tiny bubble and pin hole in the sidewall.
ID:	311841   Click image for larger version
esir_spd is offline
post #10 of 11 Old 03-16-2015, 02:40 PM
Cyclotron's Avatar
I won't buy any Dunlop motorcycle tires after my last pair. This is on my old 2011 GSXR750. I had less than 1,000 street miles on these tires, no track use. I check my tire pressures every time I ride. The front seemed OK but I got my dealer to give me a refund on the pair and sold me a pair of Pilot Powers.
Cyclotron is offline
For Sale: Used Factory Kawasaki Bandit Tire Warmers kawdude636 Parts, Gear and Accessories 25 04-30-2015 12:29 PM
Defective Gen3 Clutch Cable STurner Performance and Tech 4 08-22-2010 05:24 PM
Hotbodies huggers for the '08 are defective.. Older Guy The ZX-10R 21 10-20-2008 06:45 AM
Oil filters defective? Velociraptor The ZX-10R 6 07-22-2008 07:38 PM
front rim defective?? johnnyZX10r The ZX-10R 4 08-17-2004 02:45 PM
