Electronic Ohlins or regular? - Kawasaki ZX-10R.net
post #1 of 45 Old 11-10-2014, 09:08 PM Thread Starter
fastbydrmike's Avatar
I want to know what you guys think. I am trying to decide between a electronic controlled Ohlins or the regular Ohlins for my 2013 ZX10R. My local Ducati mechanic who is great is telling me not to do the electronic one and go with the regular TTX. He said the electronic is junk as it is on the Panigali. So I would like your thoughts on both.
fastbydrmike is offline
post #2 of 45 Old 11-10-2014, 10:35 PM
Teeks's Avatar
I think it depends on how you are going to use it and your knowledge of all things suspension.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #3 of 45 Old 11-10-2014, 10:57 PM
I have the electronic unit, nothing wrong with it, put the correct spring and preload on and its great allrounder, if your pushing the limit at a particular track then manual is better as can tune it for that circuits particular layout, not relying on an algorithm to sort things.
RBZ10R is offline
post #4 of 45 Old 11-10-2014, 10:59 PM
LDH
LDH's Avatar
You cannot compare OEM electronic Ohlins shocks to aftermarket Ohlins Electronic shocks. IF you're mechanic is as great as you say he is then he should know that.
If you are just street riding and the occasional trackday then the electronic shock is excellent.
If you are racing or track only which means you will likely also be investing in a linear race linkage then get the conventional TTX-GP which is going to have to be custom valved anyway.
LDH is offline
post #5 of 45 Old 11-10-2014, 11:05 PM
TurboR1's Avatar
Street riding and occasional track riding go electronic (set preload and forget the rest)
Racing full manual adjustment to fine tune your suspension.
Considering the electronic unit only detects which power mode you are in and then operates within a preset range of parameters.
TurboR1 is offline
post #6 of 45 Old 11-11-2014, 07:36 AM Thread Starter
Thanks for the replies. I was an expert racer and had over 12,000 track miles on my Ducati 999R. The mechanic I spoke of knows how I ride so maybe that is why he said to go with conventional. He does think the electronic doesn't work well even on the Panigali. I think I will go with the electronic since I will not be racing the bike. It will see a lot of track time and Sunday morning rides. I ride my Harley more than the 10R.
post #7 of 45 Old 11-11-2014, 12:07 PM Thread Starter
Ok, I am switching my after talking to a lot if people. I am going with the conventional TTX.
post #8 of 45 Old 01-13-2015, 08:01 PM
Somefun's Avatar
I'm wanting to do the rear shock and I was thinking of the electronic.... The bike is modded to the hill and I plan on doing more track days this year but that might be say 6 or 7. Then the rest will be limited street.....
Spegler SS lines with EBC HH pads front n rear along with Brembo M4 calipers, EBC front and rear rotors, Brembo Radial MC & Brake Levers, Sato rear sets, BST carbon fiber wheels, Pirelli Diablo Super Corsa SP, Ohlins TTX EC Rear Shock, revalued steering damper, leatec gas cap, Don Guhl Reflash, Akropovic & linked pipe. HM quick shifter,green silicon hoses, Shoria battery and shimmed the rear 5mm and lastly (for now) an EBC Kevlar race clutch & HD springs, Vortex case covers.
Somefun is offline
post #9 of 45 Old 01-21-2015, 01:32 PM
As far as I'm aware the ZX10R Mechatronic is completely different to what's on the Panigale.
The Panigale electonic ohlins basically just adjusts the damping to a fixed position depending on what mode you set it too. It basically makes one single adjustment for you as if you had just turned the screw 1/2 a turn in manually. It is in no way dynamic.
The Mechantronic on the ZX10R differs. The mechatronics system reads all the rider inputs such as rpm, gear, engine mode, constant throttle or opening throttle etc. and then layers in mph and lean before adjusting the damping of the shock. So it doesnít matter what pace youíre at or what youíre doing, the shocks damping will always be at the optimum.
BladeRR8 is offline
post #10 of 45 Old 01-25-2015, 02:53 PM
Can you fit the shock without taking the tank off as the manual instructs ?
BladeRR8 is offline
Ordered OHLINS Electronic Shock for my 2013 zx10r alex2944 The ZX-10R 13 08-08-2015 09:30 AM
Gen 4: Finally installed OHLINS electronic shock alex2944 The ZX-10R 21 06-05-2013 01:50 AM
Gen 4: Ohlins Mechatronic Electronic Shock Review purebusiness1 The ZX-10R 47 02-06-2013 02:41 AM
Gen 4: Ohlins electronic rear suspension Older Guy The ZX-10R 1 01-14-2012 12:42 PM
Gen 4: Ohlins Moto GP Replica & Electronic Control Shock Vonstallin Performance and Tech 5 12-27-2011 10:35 PM
