Do I need to switch out my tire? - Kawasaki ZX-10R.net
post #1 of 2 Old 04-29-2015, 11:46 PM Thread Starter
So I got home from riding today and I found a small copper rod stuck in my tire. It was about 1mm wide and 3-4mm long (it wasn't deeper than the tread) and right in the center. Should I replace the tire or will it be fine? The tire only has about 1250 miles on it.
I didn't notice a leak and I'll probably check the pressure in the morning.
Peaquat is offline
post #2 of 2 Old 04-30-2015, 12:21 AM
Crash Test Dummy
Hernando's Avatar
Send a message via Yahoo to Hernando Send a message via Skype™ to Hernando
No.
Bear Jew
Hernando is offline
Gen 1: How to cancel the ignition switch to a toggle-style switch. Nofoot The ZX-10R 26 09-06-2017 04:23 PM
Gen 4: clutch switch ***which wire is "ground clutch switch signal"? mdallas The ZX-10R 3 03-17-2014 01:59 PM
MSD TPS Switch and Window Switch kllrvet Parts, Gear and Accessories 4 09-08-2013 03:52 PM
Gen 3: euro switch/headlight tail light off switch tc10 The ZX-10R 0 02-10-2013 10:12 PM
Brembo Micro Switch & Billet Alum. Switch Bracket silversv1k Vendors deals 1 06-24-2008 12:15 PM
