Cut fork return to stock - Kawasaki ZX-10R.net
post #1 of 2 Old 05-03-2014, 05:10 PM Thread Starter
Hey everyone, the previous owner of my bike cut the spring spacers in the forks to lower the front end. I'm trying to return it to stock ride height, but cannot get to the locking nut for the fork cap due to the shorter spacer.
I have a racetech spring compressor as I used to do a lot of forks, but never dealt with this problem before. How the hell can I get them apart to install the stock spacers and a new set of seals?
goingtoscotland is offline
post #2 of 2 Old 05-03-2014, 05:14 PM
SkyDork's Avatar
Try getting another person to pull the cap up while you're compressing the spring.
If that doesn't work, remove the entire cartridge with the bolt at the bottom of the fork. Take that out and the entire thing should come out.
#WordCrimes
SkyDork is offline
Gen 4: Stock front fork height? tasos The ZX-10R 1 01-20-2012 02:04 AM
Trade: zx10 lowering links and cut/welded kickstand for stock! blink. Wanted: Buy or Trade 5 09-21-2011 05:05 PM
Gen 2: cut forks, throttle bodies, pingle airshifter bracket, stock rearsets and more fbmbks Parts, Gear and Accessories 6 03-04-2011 02:37 AM
ZX10r 8" stretched stock swingarm cut and welded!!!! must go!!!! garth285 Parts, Gear and Accessories 9 09-30-2007 08:24 PM
Anyone cut the stock exhaust? atf8611 Performance and Tech 16 10-11-2006 09:37 PM
