>> Bottoming Out Forks << - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By Bottoms-Up
post #1 of 5 Old 09-11-2019, 02:57 AM Thread Starter
Melampus's Avatar
Question >> Bottoming Out Forks <<
So I had OEM forks & shock rebuilt with RaceTech springs to my weight, and I just got them installed. I have yet to tune them or even set sag, and I know I need more preload in the front as I've bottomed them out twice while braking over a bump in the middle of the same corner entrance. I'll be coming in on the brakes, and as soon as I hit this bump, I felt the incredibly unsettling thud of the already loaded forks bottoming out while absorbing said bump.
My question is this: Is this damaging the forks? Does bottoming out your fork damage them?
Embracing the silence amid a life & land full of static...
Melampus is offline
post #2 of 5 Old 09-11-2019, 05:11 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
There is a bump stop at the very limit of fork's travel to prevent damage so don't be too concerned at the moment.
The preload is important to set for the rider sag but don't forget the compression damping. The idea is to control the upward stroke of the fork to keep it from maxing out. The first thing you should do is set the preload to your weight, then set the clickers to the factory settings. Then see how it reacts.
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #3 of 5 Old 09-11-2019, 09:33 AM
Bottoms-Up's Avatar
What is the Preload set at?
What is the Rebound set at?
What is the Compression set at?
What is the oil level set at?
What weight oil did they use? (Brand / Weight)
What weight spring did they install vs the OEM? Why did you think you needed to change the springs?
What did you set the sag at?
I wouldn't worried about hurting the forks, I'd be worried about crashing!
evallarta1 likes this.
Bottoms-Up is offline
post #4 of 5 Old 09-11-2019, 09:42 AM
ddipaola's Avatar
This is a really good video to watch to get the basics on sag, compression, and rebound damping. Setting the sag can be tedious so I skipped that personally. I used video 2 to at least get a good baseline before having some trackside suspension guys work their magic. When those guys got the sag right though WOW... night and day difference and now the bike, as heavy and long wheelbased as she is, just throws itself into turns and induces lean angle.
When in doubt... send it!
ddipaola is offline
post #5 of 5 Old 09-11-2019, 04:25 PM
evallarta1's Avatar
If you weren't having a problem before you sent them in and now you are having a problem check to see what the different is. Dunno what the process is for RT but at our shop we give you the suspension back with the same settings you gave them to us at. The damping may not be set.
Also RT doesnt have springs that are bike specific. They use washers to take up the slack if needed. We've seen those spacers shift in the tubes and cause false bottoming. Not much the internet can do, so go out and see what the suspension is set at.
Velocity Calibrations
evallarta1 is offline
