Blown Fork Seal, how much???? - Kawasaki ZX-10R.net
post #1 of 38 Old 05-16-2012, 05:23 PM Thread Starter
Heavyweight's Avatar
My fork seal just blew out and it leaking bad, how much does this usually cost? Is this a DIY fix?
Livin The Dream
Heavyweight is offline
post #2 of 38 Old 05-16-2012, 05:49 PM
SkyDork's Avatar
It's a DIY fix if you take your time and are mechanically inclined. If not, you're best bet is to take it in. The forks have to be completely disassembled and that usually requires a spring compressor to get the fork tubes apart. The easiest and cheapest route to go is pull the fork tubes off the bike and take them to the dealer. It will cost anywhere between $200-250 for both of them. And I definitely recommend doing both at the same time. If one is blown, the other isn't far behind likely. The seals and dust seals run about $30 in parts and are included in that cost I referenced.
#WordCrimes
SkyDork is offline
post #3 of 38 Old 05-16-2012, 09:50 PM
WhackyWheels's Avatar
I paid 400 for mine to be done. I'll work on my engine and stuff but the only thing i wont fuck with is suspension.
WhackyWheels is offline
post #4 of 38 Old 05-16-2012, 09:58 PM Thread Starter
Whacky, what all did they replace on yours for that price? Just the seals on both forks?
Livin The Dream
post #5 of 38 Old 05-16-2012, 10:35 PM
Post Whore
-Op-'s Avatar
I had mine done in a shop. Took them off and in for them to work on it. Paid around $210, parts and labor. And what SkyDork said. Do both. Its like headlights on a car. If one goes, the other is probably not far behind. Just better to do it now.
-Op- is offline
post #6 of 38 Old 05-17-2012, 08:52 AM
They replaced both and did the uninstall/install
Sent from my iPhone using MO Free
post #7 of 38 Old 05-17-2012, 12:23 PM
Starbucks Connoisseur
Static IP's Avatar
mine are blown too, just found out a week ago.
Does it matter what seals and oil is used?
Def go with OEM or what's recommended?
Is that dust cover thingy necessary too?
09' Ice Blended Peppermint Mocha Frappuccino
10' Venti Mocha Latte spilled some of it, was too hot
11' Peppermint Mocha W/Extra Shot of Espresso
12' Eggnog Venti Latte
13' Bagel
14' Standard Drip (since a Venti latte went up 20 cents)
Static IP is offline
post #8 of 38 Old 05-17-2012, 12:51 PM
SkyDork's Avatar
All Ballz Racing makes a seal and wiper kit that is pretty decent. $30 or so and you get both oil seals and both dust seals. OEM isn't bad either if you can't get the All Ballz kit.
Yes, replace the dust seals as well. They may have contributed to the failure if they are worn out and/or let some road debris by that cut the seal. Oil is your preference on the weight (heavier or lighter) and brand. Ohlins makes fork oil and it's not too expensive. I think a 5w oil is standard, but you could go 10w or even 15w depending on what you're looking to get out of it.
#WordCrimes
SkyDork is offline
post #9 of 38 Old 05-17-2012, 12:59 PM
Static IP's Avatar
Thanks!
But serioulsy, you need to go open up a bike shop.
Next to a Starbucks too.
13' Bagel
post #10 of 38 Old 05-17-2012, 01:00 PM
Speed Freak
garth285's Avatar
garth285 is offline
seal mate (fork seal tool) ghw1972 The ZX-10R 0 08-16-2011 12:28 PM
Gen 2: Fork seal change/fork oil.......again. Lycanthrope Performance and Tech 3 05-11-2011 03:34 PM
Cause of Blown Fork Seal - 2006 Mattercyclist Performance and Tech 22 04-10-2010 03:55 AM
'06 fork seal help... ZX10Aviator Performance and Tech 31 09-18-2009 08:47 AM
Blown Fork Seals toolucky Performance and Tech 14 10-06-2007 05:48 PM
