Big Piston Fork Interchange - Kawasaki ZX-10R.net
post #1 of 8 Old 11-23-2013, 01:14 PM Thread Starter
I have a Gen 3 and suspect my forks are slightly bent.
I found a set of 09 zx6r "Big Piston" forks and triple clamps for $350
Will these interchange onto my Gen 3 and are the "Big piston" forks a real improvement?
Pedestrian is offline
post #2 of 8 Old 11-23-2013, 03:35 PM
or10r's Avatar
The 6r forks are 41mm and the 10's are 43.
or10r is offline
post #3 of 8 Old 01-15-2014, 10:09 PM
manuelhung's Avatar
They'll interchange, you just have to have your steering stem pressed into the 6r triple.
manuelhung is offline
post #4 of 8 Old 01-17-2014, 08:17 PM Thread Starter
That's what I was looking for. Thanks
post #5 of 8 Old 01-22-2014, 08:25 PM
kneedragger's Avatar
Can you swap" Big Piston Fork" into a Gen 2 ZX-10R ?
I'm not fast I'm just faster than you
Bikes owned
97 ZX11, 98 R1, 00 CBR929, 02 RC51, 02 Duc 998, 02 GSXR 1000, 04 GSXR 600, 05 ZX10R, 05 ZX6R, 06 Husky TE 510, 07 ZX6R, 04 GSXR 750, 2001 CBR929RR, 2007 ZX10R SE Hows my resume
kneedragger is offline
post #6 of 8 Old 01-22-2014, 08:30 PM
manuelhung's Avatar
Yup, you'll need to swap the stem aswell and also use 6r or aftermarket clip ons
post #7 of 8 Old 01-23-2014, 06:57 AM
Keep in mind that changes in overall fork length will alter handling characteristics. Fork from a 6r may not have a desirable spring rate or valving for your setup.
2016 GSX-S1000
08 10r Sold
Walter is offline
post #8 of 8 Old 01-23-2014, 08:28 AM
manuelhung's Avatar
Yes the 6r forks are longer than gen2 forks so you'll have to have 10-15mm of fork above the top triple to get same geometry....you'll have to figure out if the internals are suitable for your weight.
Big Piston Fork Oil Change kman0066 Suspension and Tire Tech 23 06-23-2016 09:09 AM
Fork caps for showa big piston forks. Red blownhotrodder Parts, Gear and Accessories 6 02-22-2013 11:07 AM
Gen 3: ZX6 big piston forks kllrvet The ZX-10R 11 06-28-2012 06:03 PM
Wheels interchange??? bodymanruss518 ZX-9R Discussion 15 07-02-2008 12:59 PM
Do 04-05 frames interchange with 06-07?? hibshman25 Performance and Tech 9 11-14-2007 08:36 AM
