Anyone ditch the stock electronic steering stabilizer for aftermarket one? - Kawasaki ZX-10R.net
 4Likes
  • 1 Post By ZX10RArcher
  • 1 Post By Niner1000RR
  • 2 Post By ZX10RArcher
LinkBack Thread Tools
Old 07-14-2016, 07:11 PM Thread Starter
KIXASS's Avatar
I don't really like the factory electronic steering stabilizer. Anyone go with aftermarket unit? If so what do you recommend?
Will removing factory unit cause fault light to come on? If so can I turn it off through Woolich racing software?
Thanks.
KIXASS is offline
Old 07-14-2016, 08:17 PM
No, it isn't part of the main FI ECU. It is controlled and governed solely by the SCU. The only place the main FI ECU fits into the grand scheme of things is that it shares info with the SCU where the SCU then makes the determination to adjust and to what degree and if there is issues with it, to flag an FI code/light.
SkyDork likes this.
ZX10RArcher is offline
Old 07-15-2016, 07:50 AM
SkyDork's Avatar
To Archers point, yes you will get an error light if you remove it. And what Archer said is there's no way to get rid of it currently.
There's threads on how to retain the control module off of the ESD to keep the error light from illuminating when switching to an aftermarket one.
#WordCrimes
SkyDork is offline
Old 07-15-2016, 08:11 AM
Niner1000RR's Avatar
Yea on my Gen4, I pulled the little motor out of the end of the ESD, plugged it in and secured it under the tank. Then I installed the Ohlins manual damper.
ZX10RArcher likes this.
Niner1000RR is offline
Old 07-15-2016, 10:43 AM
Yup^
Only way to do it. TDH did up a video on how to disassemble the motor from the damper. Should be able to find it on the boards by searching.
-Anthony
Niner1000RR and Ranjit1194 like this.
Old 07-22-2016, 06:30 AM
Is the damper not sufficient for street use? I know little to nothing about them by the way.
Kllongbrake is offline
Old 07-22-2016, 11:10 PM Thread Starter
KIXASS's Avatar
I just don't like when I'm wide open throttle and the frontend starts to dance it moves around WAY more than I'm comfortable with and I have no way of adjusting it.
Those of you who have swapped theirs out, what did you replace it with? GPR V4 any good?
Thanks.
KIXASS is offline
Old 07-23-2016, 05:06 PM
Stock Gen4 pre-ESD, modified by Kyle Racing. Bought the used OEM Gen4 damper off eBay ($150) and sent to Dan for mods ($85) for a total cost of $235 vs new Ohlins for $400 or GPR for $450.
CanyonCarver is offline
Old 07-23-2016, 07:33 PM
White Fang's Avatar
I got some serious headshake the last couple of rides, darn near tankslappers, you hit that throttle hard and whack some bumps and it's a puckerfest. Yeah I am riding the bike harder and harder every time so that Ohlins SCU is on the short list of stuff to do.
Sturm und Drang
White Fang is offline
Gen 4: Electronic Steering Damper Ericnguyen1989 Wanted: Buy or Trade 0 01-01-2015 11:25 PM
electronic steering damper dextroy155 The ZX-10R 0 03-01-2013 09:09 PM
Gen 4: Stock Ohlins Steering Damper Stabilizer 1fast10r619 Parts, Gear and Accessories 4 02-28-2013 12:22 PM
electronic steering damper dextroy155 The ZX-10R 0 02-22-2013 08:45 PM
