Another fork seal ? - Kawasaki ZX-10R.net
post #1 of 14 Old 06-11-2012, 10:52 PM Thread Starter
Another fork seal ?
Just tore down my forks to replace seals. The seals and washers underneath the seals were both put on different by po. One of the seals, the writing was facing up, one was facing down. Same with the washer, the flat part was up on one down on the other.
Anyone know which way they are supposed go?
Thanks for your time!
kawdawg is offline
post #2 of 14 Old 06-11-2012, 11:04 PM
SpazOnaZX's Avatar
Wow.
With the washers I haven't ever found it to really matter so long as they are free of damage/burrs, but the seals are certainly uni-directional. The large side of the seal (with the writing stamped on it) should face the dry side of the fork. I -think- the service manual has an illustration of which they should go.... did you check in the front fork section for that?
It's hard for me to find how to explain it, but almost all shaft oil seals in this type of application have seal faces that are asymmetrical... you can see which side would be better for wiping (cleaning the shaft), and which side would be better at holding fluid pressure (sealing) by the way the face of the seal, erm, "faces", and the direction of the taper off the face of the seal.
Too confusing?
SpazOnaZX is offline
post #3 of 14 Old 06-12-2012, 08:27 AM
evallarta1's Avatar
Rub your finger over the edge of the washer, youll feel a sharp edge on one side and a rounded off side on the other. The sharp edge always goes against the seal, and the the rounded off part always goes towards the tube.
As for the seal I dont have one infront of me to look at. Hopefully someone can chime in.
Velocity Calibrations
evallarta1 is offline
post #4 of 14 Old 06-12-2012, 08:41 AM Thread Starter
I did not catch that in the service manual. After looking at the seals more closely, I can see what your talking about. I'm putting them back together today, if you think of any other tips tricks, please let me know.
Thanks for your reply.
kawdawg is offline
post #5 of 14 Old 06-12-2012, 08:51 AM Thread Starter
I thought it would go the opposite way. I guess I'll give it a try.
Thanks
kawdawg is offline
post #6 of 14 Old 06-15-2012, 02:56 PM
The Movie Goer!
ZiG 9th's Avatar
Send a message via AIM to ZiG 9th
When changing the seals should you also change the washer an snap pin?
<img src=http://i261.photobucket.com/albums/ii64/thebluehanger/Thriller.gif border=0 alt= />
Quote of the year! lol!!
"1 shut the fuck up 2 ur opinion doesnt count on this kind of page where saw fans come together 3 you fucking liked you own comment thats fucking pathetic!" -Brandon Welbig
ZiG 9th is offline
post #7 of 14 Old 06-15-2012, 05:50 PM Thread Starter
I reused mine. It seems most people reuse unless their damaged. I just finished mine up using the write up and service manual ect and all is well so far :)
kawdawg is offline
post #8 of 14 Old 06-16-2012, 05:28 PM
The Movie Goer!
ZiG 9th's Avatar
When you buy new seals do they come with the seals or do you have to buy them separate?
ZiG 9th is offline
post #9 of 14 Old 06-16-2012, 06:38 PM Thread Starter
With oem, their separate. Not sure about aftermarket
kawdawg is offline
post #10 of 14 Old 06-16-2012, 08:57 PM
Does not drive into smoke
El Zilcho's Avatar
I don't think it really matters. There is nothing in there that would indicate that the orientation makes a difference. As a matter of fact, in my forks, the washers were placed in the opposite way---the rounded side towards the seals. (This is in gen 1.)
El Zilcho is offline
seal mate (fork seal tool) ghw1972 The ZX-10R 0 08-16-2011 12:28 PM
Gen 2: Fork seal change/fork oil.......again. Lycanthrope Performance and Tech 3 05-11-2011 03:34 PM
Fork seal How to? loueber The ZX-10R 26 01-16-2010 12:47 AM
Fork seal Help fatcalvin Performance and Tech 2 06-14-2007 11:46 AM
Fork Seal nmorris02 The ZX-10R 3 05-22-2007 05:54 PM
