Adjustable triple clamp - Kawasaki ZX-10R.net
post #1 of 13 Old 05-07-2014, 10:44 AM Thread Starter
dricked's Avatar
To those running them on the gen 4, what offsets are you using?
dricked is offline
post #2 of 13 Old 05-14-2014, 10:05 AM Thread Starter
dricked's Avatar
I guess nobody has a set? I ordered mine with the -/+ 2mm eccentrics so I guess I'll figure it out.
dricked is offline
post #3 of 13 Old 05-14-2014, 10:54 AM
May want to direct LDH to this thread, I'm sure he would have some input.
shakazulu12 is offline
post #4 of 13 Old 05-14-2014, 02:02 PM
or10r's Avatar
fireman69 may also be able to help.
or10r is offline
post #5 of 13 Old 05-14-2014, 04:26 PM
RIKKITIK's Avatar
You will probably find you want to experiment anyway. I'm not sure there is a "magic" number for offset, different riding styles, and setups = different numbers.
FWIW, Attack's are usually 30mm offset with 0 bushings. So your + -2mm would give you a choice of 28mm or 32mm. I don't know what OEM/standard offset is for a Gen4 (Japanese seemingly loved 26mm for years but have come around more lately). 32mm offset will be quicker/lighter turning than 28mm, generally at the expense of having less "feel". Moving the forks forward to 32mm offset shortens trail number, 28mm offset lengthens trail (from 0 offset bushing).
RIKKITIK is offline
post #6 of 13 Old 05-14-2014, 04:51 PM Thread Starter
dricked's Avatar
Originally Posted by RIKKITIK View Post
You will probably find you want to experiment anyway. I'm not sure there is a "magic" number for offset, different riding styles and setups = different numbers.
FWIW, Attacks are usually 30mm offset with 0 bushings. So your + -2mm will give you a choice of 28mm or 32mm. I don't know what OEM/standard offset is for a Gen4 (Japanese seemingly loved 26mm for years but have come around more lately). 32mm offset will be quicker/lighter turning than 28mm, generally at the expense of less "feel". Moving the forks forward 32mm shortens trail number, 28mm lengthens trail (from 0 offset).
Ok well this gives me some idea of what to look for after making adjustments and what direction to go. I'm using robby moto clamps. I don't know what offset they start at but I atleast have an idea on which direction to head depending on how the bike feels.
dricked is offline
post #7 of 13 Old 05-14-2014, 05:07 PM
You are also going to have to post a lot more info. Like what shock, link, wheelbase etc.
post #8 of 13 Old 05-14-2014, 05:50 PM Thread Starter
dricked's Avatar
I'm going to be using a ktech shock with the Kyle racing linkage and I'm not sure on wheelbase yet and I'm open to suggestions. I'm sure my tuner will have an idea but I like to know as much info going into things as possible.
dricked is offline
post #9 of 13 Old 05-14-2014, 07:10 PM
What other companies have adjustable triple clamps for the gen 4 aside from Attack Racing? They're the only ones I've come across since 2011.
AnabolicZX10R is offline
post #10 of 13 Old 05-14-2014, 07:31 PM Thread Starter
dricked's Avatar
These guys
http://bluestreakracing.ca/suspensio...le-clamps.html
and these guys might but you'd have to double check the dimensions
http://www.imasrl.com/index.php?opti... mid=7&lang=en
dricked is offline
Gen 2: Too clamp/triple tree.. 06blackpearl Parts, Gear and Accessories 0 07-03-2013 07:17 AM
Gen 3: Triple Clamp mrbzx7 Parts, Gear and Accessories 1 09-03-2012 08:22 PM
Triple Clamp woodywoodpecker The ZX-10R 2 05-10-2011 04:10 PM
Has anyone fitted a 06-07 Triple Clamp on a 04-05? 9R to 10R The ZX-10R 10 01-02-2010 03:37 AM
06-07 triple clamp zx-sik-r Performance and Tech 0 07-06-2008 02:52 PM
