08 zx10 susp? - Kawasaki ZX-10R.net
post #1 of 16 Old 10-05-2013, 08:15 PM Thread Starter
08 zx10 susp?
Just looking at upgrading my 08 zx10 front forks and have a couple of options either ssk ktech piston kit or a ohlins piston kit .Just wondering which way i should go ?The roads i ride a bit rough uneven .Not sure what i will do with the rear shock yet maybe revalve respring or after market elka .ohlins or penske just need to get this 10 sorted asap.
shakey is offline
post #2 of 16 Old 10-05-2013, 10:53 PM
Lee V's Avatar
Hi matey
Both ohlins and K-tech kits are good quality.. and far better than your stock road forks.
I ran Ohlins on my Gen3 and then outed them for K-tech,
K-tech are easier to get that sweet spot with esp when playing with settings your self.
Lee V is offline
post #3 of 16 Old 10-06-2013, 01:44 AM Thread Starter
Cheers lee v i recon my 08 zx10 forks are terribly harsh I've had trouble with my zx wanting to tuck at full lean not the best feeling.I have heard great things about ktech pity they don't make a rear shock for a 08 zx10.
shakey is offline
post #4 of 16 Old 10-07-2013, 12:44 AM
Lee V's Avatar
Blimey, that don't sound too good, what tyres and pressures are you running? that can make a huge difference to suspension set up.
Lee V is offline
post #5 of 16 Old 10-07-2013, 04:13 PM Thread Starter
Lee v i run 32f 32r dunlop sportsmarts best tyre I've used going for a spin today through granya gap. lockarts gap.happy valley .towanga gap. mnt buffalo .This will mean nothing to u but to australian members these roads are some of the best of the best .A bloke told me with the sportsmarts i could go to 30 30 for road use .The 08 zx10 I'm loving it especially with the high bars awesome in the twisties. Anyway just heading out to put the leathers on have a good day.
shakey is offline
post #6 of 16 Old 10-07-2013, 06:11 PM
BratNetwork's Avatar
What springs do you have in the forks? Stock? Rear? How much do you weigh?
I did the Ohlins front cartridges and Penski rear and WOW! what a difference. Ohlins rear would probably be better. Make sure you get the springs spec'd right for you for both. From the factory they are terribly unbalanced. As long as you get the spring rates sorted, along with any valving upgrades, sag set and clickers adjusted right you will be happy with it. Will feel like a new bike.
2008 ZX-10R | Black | Arrow Headers | AreaP Slip-on CF | K&N Filter |GUTS ECU Flash By Guhl Motors | Block-Off Plates | Fender Eliminator | Clear Alternatives Integrated Taillight | Rifleman's 1/5th Throttle Insert | Speedohealer | Pro-Grip 719s | Vortex Bar Ends | Puig Z DB Windscreen | CBR1000 Mirrors | Vortex 520 Sprockets -1/+1 | RK Gold 520 Chain | Galfer SS Lines | Pazzo Shorty Levers | Vortex Gas Cap | Rebuilt Damper | Lightech Rearsets | Much More To Come
BratNetwork is offline
post #7 of 16 Old 10-07-2013, 08:21 PM
evallarta1's Avatar
This might help persuade you. Ohlins is running a sale on fork piston kits, here in the states they're almost $100 off.
Velocity Calibrations
evallarta1 is offline
post #8 of 16 Old 10-07-2013, 10:13 PM Thread Starter
All stock standard front and rear and i weigh 95kgs with leathers on . The zx is mainly for fast road I've had my eye on a elka rear shock from the states only 870 delivered or a penske. The ttx is just a bit to much as i could get the forks done and buy a penske or elka for less than the ttx+for road riding i wouldn't be able to tell the difference.I would probably rather do that then pump $ into the stock rear as set up for me would cost me around the 400.500 mark .I am going to do the forks first and make a decision on the rear later. ktech or ohlins for the forks i need help to make this decision .Cheers everyone for the input
shakey is offline
post #9 of 16 Old 10-07-2013, 10:45 PM
smalls23's Avatar
Send a message via AIM to smalls23
shakey check this thread. You should be close on weight so you may be able to get some great parts.
It seems like gobig may have some parts you could use.
https://www.zx-10r.net/forum/showthread.php?t=173945
smalls23 is offline
post #10 of 16 Old 10-08-2013, 02:11 AM Thread Starter
Cheers smalls23 i will check it out
shakey is offline
how to start tuning susp on my own nyrep1 Performance and Tech 3 08-29-2008 01:50 AM
Sport Rider zx10 susp. settings different for 04/05? NYC_ZX10 The ZX-10R 1 08-28-2008 02:47 PM
Hey Susp. Guys!!!..help! bodymanruss518 Performance and Tech 11 02-18-2008 01:24 PM
10 susp on 6? kawiiiiii Performance and Tech 1 07-23-2007 03:00 PM
Help me Adjust Susp To My Weight ILU2792 Performance and Tech 5 05-31-2007 03:55 PM
