08 zx10 rear shock help - Kawasaki ZX-10R.net
post #1 of 4 Old 07-05-2012, 11:01 PM Thread Starter
My buddy s bike is lowered and stretched bout 6". the other day the rear got real soft, and the damping "resovior" part is hitting the swing arm. Is it gas or fluid? There is no leaking of fluid, n wen bounced I heard no air leaking. It appears the nut has the spring copressed all the down. Any ideas? Bad valve or maybe just shot?
Omahaguy is offline
post #2 of 4 Old 07-05-2012, 11:15 PM
Tee's Kawa55's Avatar
when you stretch a bike you've already pretty much exceeded the limit of the shock. it doesn't matter if the shock is new or not. You will pretty much have to upgrade the internals and/or get a stiffer spring to counteract the length of the extended arm.
DDM Tuning HID lights| Sportech Windscreen| ASV shorty levers| Driven D3 grips| Evotech 1/4 turn gas cap| LSL sliders| Woodcraft case covers| PCV with custom map| BMC race filter| secondaries removed| EK 525 red chain| Vortex rearsets| M4 Slayer exhaust| PSR chain adjusters| Speigler brake lines| custom front and rear seat| Pro bolt aluminum bolt kit| Hellrazor servo eliminator
Tee's Kawa55 is offline
post #3 of 4 Old 07-05-2012, 11:18 PM Thread Starter
so you think he blew it then, and if so do you think another factory shock w stiffer spring will work? Also wher to get that spring and what weight?.
Thanks for helpn me out.
Omahaguy is offline
post #4 of 4 Old 07-06-2012, 10:23 AM
No I don't think he blew the shock but he's increased the length of the lever (swing arm), which will place more pressure on the pivot point (shock) and will cause it to work too hard. I have a buddy whose bike is the same way. Your buddy will either have to beef up the internals or spring rate or install a strut, but that will give him a very harsh ride.
Wanted: 08-10 zx10 Rear Shock Muddy Wanted: Buy or Trade 1 02-18-2012 09:37 PM
08 zx10 rear shock for sale 1300hemibusa Parts, Gear and Accessories 23 10-13-2008 07:34 PM
08 zx10 rear shock F/S 1300hemibusa Parts, Gear and Accessories 3 10-06-2008 05:06 PM
06-07 ZX10 Rear Shock JoeySV Wanted: Buy or Trade 1 03-12-2008 02:47 PM
06 zx10 rear shock mount steved57 Performance and Tech 2 10-21-2006 07:43 PM
