Gen 4: 2011-2015 ZX10RArcher Aggressive Flash, Flashed ECU - Kawasaki ZX-10R.net
post #1 of 7 Old 09-22-2014, 02:27 PM Thread Starter
I just heard back from the eBay user Cycle Reapers with my serial number.
Serial number 0056. This ECU flash was accomplished on March 12th, 2014 by me, for a customer initials A.P. from Clewiston, FL.
Bike was flashed with my aggressive flash /w 14K rev limiter. So if someone is wanting a flashed ECU and keep their stocker just in case... there you go!
http://www.ebay.com/itm/271581994837...S:1123&vxp=mtr
11 Hours left to buy!
ZX10RArcher is offline
post #2 of 7 Old 09-23-2014, 06:30 AM
Baddie's Avatar
I wonder if that will connect differently to Euro bike?
Can you Pm what that will cost if I was to send mine to you Archer.
Baddie is offline
post #3 of 7 Old 09-23-2014, 10:49 AM Thread Starter
It will connect all the same. The only thing is your immobilizer function will not function any longer if you're flashed with a US/North America-based ECU Bin file.
I have done plenty of bikes overseas with my flash and it is easy to keep your immobilizer function in tact. It may take a day longer processing time to make sure I have everything right, but so far every ECU I've sent to Singapore, Japan, Australia and the UK have been okay and they have been pleased.
PM me your shipping address and I will get you shipping quotes. Headed out of the states I usually give two quotes; one for a regular shipping speed and another for expedited. Typically the prices aren't too much different. Going off memory it's roughly $10 more than my US prices to send overseas for 6-10 day and $18 more than my US prices to send overseas for 3-5 day. But I won't know for sure until I get your shipping info.
post #4 of 7 Old 12-31-2014, 05:37 AM
Hey there, will this ecu work on a 2013 bike?
Dwikster is offline
post #5 of 7 Old 12-31-2014, 03:02 PM
Baddie's Avatar
Hey Archer
Just looked at Ebay listing what the following code mean that are crossed out on piece of paper?.
I've just had my flashed and I was lucky to get a copy of someone who had been saving Data log for sometime.
ESM...FC...TSR...OIT...OST?
Baddie is offline
post #6 of 7 Old 12-31-2014, 03:45 PM Thread Starter
Yes.
Originally Posted by Baddie View Post
Hey Archer
Its just the features or changes in the flash.
ESM Exhaust servo motor FI light
FC Fuel Cut removed
TSR Top Speed limiter Removed
OIT Optimized ignition timing
OST Optimized secondary throttle plates
TC Traction Control off on the fly
TCS retain Traction Control Setting
O2S Remove O2 Sensor
RPM is what the limiter is set to
Other is any notes about mapping
post #7 of 7 Old 12-31-2014, 04:05 PM
Baddie's Avatar
Cheers :)
Baddie is offline
Gen 4: Guhl flashed ecu Tech5 Parts, Gear and Accessories 4 07-16-2014 03:46 PM
Gen 3: Stock ecu flashed craig_sez Parts, Gear and Accessories 2 04-29-2014 09:02 PM
Gen 4: Guhl flashed ECU StZixxer Parts, Gear and Accessories 13 08-09-2013 08:44 AM
Gen 4: Guhl flashed ecu SteedaGT Parts, Gear and Accessories 11 02-16-2013 01:29 AM
Re-Flashed ECU torquezx9r Performance and Tech 291 11-04-2012 08:31 PM
