Ok figured I'd make a new thread on this as there's just a ton of crap in my build thread, they will be linked for those who care. Will post a build sheet here of what was done to the best of my knowledge. She's done for now, yes its ridiculously fast, and yes you can ride it with a huge ass deposit.
Practically everything was bought from Oppracing
Parts List:
Bodywork/Lighting/Accessories
Carbon Fiber:
Macmoto: Upper, lower, SBK tail, anti-draft, frame and swing arm covers(clear coated by HK)
Akrapovic: front fender, rear fender, chain guard, tank panels
Custom foam seat
ETI fuel cell Carbon Wrapped(thanks HK!) 20 liters (with gas tank foam)
Zero Gravity Corsa windscreen
Maddog Fender eliminator
Greg's turn signal block off plates
CRG 3" full pivot bar end mirrors
Lightech engine and fairing bolts aluminum
Lightech rear axle nuts and swing arm pivot nut
Lightech frame sliders
Lightech swing arm spools
Lightech chain adjusters
Lightech brake reservoir caps front and rear
Lightech oil cap
Stomp Grips clear
Dzus fasteners
Lightweight Battery (2011 addtion second attempt lol)
Cox Radiation Guard (2011 addition)
Akrapovic exhaust hanger(winter 2011 addition)
Suspension
Ohlins Road&Track Forks FGRT804 (2011 addition)
Ohlins TTX36 Rear Shock TTXKA788 (2011 addition)
Ohlins SD-021 Damper
Lightech preload adjusters
Engine/Exhaust Related
Full Akrapovic TI cz conical exhaust
Woodcraft engine covers left and right
power commander 5 with auto-tune
Ivan servo eliminator
smog block off plates
K&N Street filter
Samco Hose kit
Brakes
spiegler ss brake lines front and rear
Brembo 19x20 Billet Radial Master Cylinder with folding standard lever, titanium bolts
Brembo HP GP4-RX Calipers with sintered pads 310 Discs
Titanium Caliper bolts (2011 addition)
Controls Hand/Feet
Lightech clip-ons with 20mm raise, titanium bolts (2011 addition)
Lightech folding cable clutch perch assembly, titanium bolts.
Lightech SBK rearsets with folding pegs and carbon heel guards
Kawasaki Kit Throttle, Titanium bolts (2011 addition)
Special thanks go out to HK, Patrick, Tim, anybody else at oppracing that worked on it that I'm not aware of and the members of ZX-10R.net who helped me decide on parts and stuff.
Build Thread
http://www.zx-10r.net/forum/showthread.php?t=82003
Dyno Graph
On the Dyno
