06-16-2010, 06:52 PM
#1
Bike: 08 zx10r
So WTF..
I know theres 9275 threads on 08's pulling to the right.. Well here lately, mines been darting off to the right.. Not so much "darting" when doing a stand up, or hands off the bars, but say a first gear hard roll on, I can already feel it wanting to pull to the right, and as soon as the front tire is off the ground, its already wanting to be in the other lane. The blocks are on the same marks, rear tire was balanced.. Its always pulled to the right but have noticed here lately that its gotten worse. Its not body position because I can be hanging off the left side of the bike and it still wants to. Anyone have any suggestions? It really only seems to pull harder under a strain.
__________________
2008 ZX-10R. | Full Arrow exhaust | PCV | BMC Race | Driven -1+2 520 conversion | Speedohealer | Man I need some more mods...
06-16-2010, 07:01 PM
#2
Try adjusting the wheel some. If it's going to the right try adjusting the exhaust side chain tensioner towards the back of the bike.
06-16-2010, 07:31 PM
#3
Bike: Pearl Solar Yellow ZX-10R
I can't say for sure, but on my 2nd gen the marks on the blocks were wrong. I had someone that had a nice alignment tool confirm this when I was getting my pures installed.
__________________
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
HST
"Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" HST
06-16-2010, 07:48 PM
#4
Bike: 2008 ZX10R GREEN
Tires too... My front is so worn it's pulling.
06-16-2010, 10:13 PM
#5
I ran brass rods through my rear axle and my swingarm pivot......
When I measured on both sides, the spwingarm marks were almost half a hash off.
I don't trust those.
06-16-2010, 10:18 PM
#6
Bike: 05 10r
My 1g does the same on the street. Wheelies perfectly straight at the track though, Ive stopped caring about it.
06-17-2010, 08:47 AM
#7
Bike: Lime Green ZX-10R
You can also use the string method. Not only can the swing arm marks be off, there is also a lot of slop between the axle and the square blocks. However, in my experience, this won't cure a pull unless the rear wheel alignment was way way off.
__________________
Green '04
06-17-2010, 08:56 AM
#8
Bike: Nothing at all - just a poser
Check your tire wear as well.
Your rear is probably worn in a different pattern (most are worn more on right than left) - when moving off your upright balance point the tire circumference changes drastically and will pull right much more quickly.
__________________
If you have nothing nice to say - "Shut the f@ck up"
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
You may not post replies
