Nitrous kit pics direct port and 2.5lbs bracket mounting - Kawasaki ZX-10R.net
Index Index Store Gallery UserCP Memberlist Calendar NewPosts
Go Back   Kawasaki ZX-10R.net > General Discussions > Pictures and Videos
Thread Tools Display Modes
Old 02-21-2010, 10:01 PM   #1
garth285
Speed Freak
garth285's Avatar
Postwhore Meter
PPD:
Bike: 335kph 2011 ZX-10r
garth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond reputegarth285 has a reputation beyond repute
Hey guys, well I'm putting the squeeze back on her... but since I sold my other nitrous kit with my other bottles I'm using the 2.5lbs bottle that was on that 12r I had...... its a 2.5lbs polished bottle and with some left over fittings and such I mounted a liquid filled nitrous gauge using a T fitting. Being that the 10r its pretty hard to hide a nitrous bottle this size even in the front fairing I wanted to make a efficient mount. So I took a stock left hand passenger peg and cut off the tabs and ground it smooth. I then made a bracket to bolt the peg assembly to the bottle bracket that I had. I had some hardware laying around so I found some really good 8mm bolts that I could run a nut on the back of so I can lock-tight everything down good.... the bracket is sold as a rock!!! I just need to make some spacers so the bracket isnt being bent in all the time, was working with what I had in the garage at the time and wanted to make sure she would hole good.... Anyways..... heres some pics
OK now for the nitrous injection part. I wanted to run a direct port nitrous set up. So I took a ride to the local murrays speed and custom and picked up a distribution block, some nylon tubing from a hardware store (temp) and some fittings I needed... I had a spare nitrous solenoid that I'm going to use which is actually way over kill but I wound up coming up with this....
I've got the jet located in the fitting that comes out of the nitrous solenoid and those lines are kinda only temporary.... I want to use the steel lines and make them exactly equal length. Even though these are only maybe a half in longer than one another I'd like to get them even. I'm also going to polish that bottle up I think, I gotta get the polishing wheel for my grinder anyways.....
I think I'm going to make the switch to running either all race gas or just a mix to keep detonation down the speed shop only had to jet sizes a .22 and a .30 which is a 17hp and a 35 according to schnitz but from what I've been told the direct injection adds the hp up a lil.... a 40 shot should be pretty good for the bike....
p.s. incase anyone is wondering about the bottle position. The bottle has a siphon tube in it which is positioned in the bottle at the same position as the valve outlet so I wanted to keep that at the lowest point in the bottle as possible this way I'm getting the liquid out of the bottle first.
garth285 is offline   Reply With Quote
Old 02-22-2010, 04:12 AM   #2
edouble
contributor edouble's Avatar
Postwhore Meter
PPD:
edouble has much to be proud ofedouble has much to be proud ofedouble has much to be proud ofedouble has much to be proud ofedouble has much to be proud ofedouble has much to be proud ofedouble has much to be proud ofedouble has much to be proud ofedouble has much to be proud of
Holy crap that bottle is huge and it honestly looks hideous hanging of the side of your bike Wouldnt the flexible tubing that you have the nitrous coming out of whip around during a spray cycle (edit: you addressed this yourself)? I have never used nitrous so I have no idea but maybe someday I will
__________________
Last edited by edouble; 02-22-2010 at 04:14 AM. Reason: edit : not reading the entire post correctly
edouble is offline   Reply With Quote
Old 02-22-2010, 04:45 AM   #3
or10r
Track Addict
contributor or10r's Avatar
Postwhore Meter
PPD:
Bike: Pearl Blazing Orange ZX-10R
Images: 14
or10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond reputeor10r has a reputation beyond repute
Holy crap, that thing is gonna haul some serious butt.
__________________
What can I do with the limited time I have to make a difference? Ed Dobson.
or10r is offline   Reply With Quote
Old 02-22-2010, 07:47 AM   #4
garth285
Speed Freak
garth285's Avatar
Postwhore Meter
PPD:
hahah yeah I know its pretty horrible but its very functional
that tubing is actually solid as a rock and doesn't move under pressure.... I'm going to replace it with steel tubing as soon as it gets in though.
Old 02-22-2010, 08:20 AM   #5
TMAC
TMAC's Avatar
Postwhore Meter
PPD:
Bike: Reflects Blue, Bleeds Green
Images: 86
TMAC has a spectacular aura aboutTMAC has a spectacular aura about
I agree with edouble, I don't think your bottle is big enough =)
__________________
2007 ZX-10R - 156 RWHP/182 MPH
2009 KX450F
2006 636 (Sold)
99 ZX-6R (Sold)
94 Ninja 250 (Sold)
99 YZ-250 (Sold)
73 CL 450 (Sold)
http://www.youtube.com/watch?v=a6Jpc...eature=related
http://videos.streetfire.net/video/H...bud_408656.htm
TMAC is offline   Reply With Quote
Old 02-22-2010, 08:21 AM   #6
FTHOODZX10R
FTHOODZX10R's Avatar
Postwhore Meter
PPD:
Bike: Ebony Black ZX14R
FTHOODZX10R is on a distinguished road
it looks bigger than my bottle
__________________
2006 Ebony ZX14
Looking for new 10
Still.....Looking for:
Carbon, Aluminum, or Magnesium wheels, rear sets, velocity stacks,
FTHOODZX10R is offline   Reply With Quote
Old 02-22-2010, 08:45 AM   #7
lowkey420
lowkey420's Avatar
Postwhore Meter
PPD:
Bike: 2006 ZX-10R GREEN!
lowkey420 will become famous soon enough
what are you trying to launch with that thing? the space shuttle?!
g/l and get a clip of it in action
lowkey420 is offline   Reply With Quote
Old 02-22-2010, 10:32 AM   #8
garth285
Speed Freak
garth285's Avatar
Postwhore Meter
PPD:
my GoPro HD will be here tomorrow (my b-day :-) ) so I'll def have some vids of her in action
Old 02-22-2010, 10:40 AM   #9
Weazel
Weazel's Avatar
Postwhore Meter
PPD:
Bike: Black 2009 ZX10R, 2008 KTM 250SX-F, and a CRF 50
Weazel is a splendid one to beholdWeazel is a splendid one to beholdWeazel is a splendid one to beholdWeazel is a splendid one to beholdWeazel is a splendid one to beholdWeazel is a splendid one to behold
Holy F-ing huge ass bottle. Coming from the land of overkill. that is awesome.
__________________
There are three rules I live my life by:
1. No matter where you are or what you are doing always look cool.
2. Don't be a pussy
3. When in doubt refer to rule number 1
Weazel is offline   Reply With Quote
Old 02-22-2010, 10:43 AM   #10
garth285
Speed Freak
garth285's Avatar
Postwhore Meter
PPD:
lol... yeah yeah yeah I know :-p its all good though, I was trying to make a bold statement
You may not post replies
Forum Jump
Powered by: vBulletin Version 3.7.3
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2003-2012 ZX-10R.net
Motorcycle News, Videos and Reviews
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
