Suspension Mods. - Kawasaki ZX-10R.net
Index Index Store Gallery UserCP Memberlist Calendar NewPosts
Go Back   Kawasaki ZX-10R.net > General Discussions > The ZX-10R
Thread Tools Display Modes
Old 04-21-2004, 09:36 PM   #1
KWAK10R
Postwhore Meter
PPD:
KWAK10R is on a distinguished road
Suspension Mods.
Hey guys, I know I've asked this before but I'm still puzzeled.
What does everybody weigh and have you done any mods. to the stock
suspension? I'm 195 lb. full gear and the bike seems to be very jumpy.
Especialy when going into corners, just as I'm about to lean in the turn
and if there is a smallest bump or dip in the road the bike is all over the
place. Is it the suspension, the tires or something else? This really freaks
me out, you know how hard it is to break once your leaned over.
Any way, your input would be much appreciated. Thank you.
KWAK10R is offline   Reply With Quote
Old 04-21-2004, 10:45 PM   #2
sp500
sp500's Avatar
Postwhore Meter
PPD:
Bike: Green ZX-10R
sp500 is on a distinguished road
Dont have a 10r yet but sounds like your compression and rebound settings may be abit on the hard side, trial and error I suppose. Try softer settings and see what it is like then, there will be some guys on here who know alot more about it than me with track experience, they'll pipe up soon enough... :)
sp500 is offline   Reply With Quote
Old 04-22-2004, 11:10 AM   #3
kuzco
Postwhore Meter
PPD:
kuzco is on a distinguished road
oh good somebody started this already. my inseem is only 30 or less and i would need to lower at least 1". is this acheivable? the salesman tells me to just move the big spring nuts up or down, but that would increase or decrease the spring rate. correct? is this how you lower it? im only 125lbs and how does this effect my weight? if the spring rate is change wouldn't it effect the comp and damper settings?
kuzco is offline   Reply With Quote
Old 04-22-2004, 05:07 PM   #4
alley cat
Postwhore Meter
PPD:
Bike: Blue ZX-10R
alley cat is on a distinguished road
Re: Suspension Mods.
i'm 185 geared up and i backed out one click front and back on the compression damping and increased the rebound two clicks front and one turn in back from the stock settings. i have 5 lines showing on fork preload adjusters and 21 mm of thread showing on the shock. for me these work well so far. it has stopped the slight kick up on rebound and everythings seems well planted and some serious trail breaking can be done at awsome lean angles with great control...
__________________
04 zx10r- blue ( Mr. Hyde )
C/F Micron high mnt./ Galfer lines/ Puig D/B/ watsen signals.
i know your fast because you were hauling ass when i passed you..
i refuse to go timidly thru life only to arrive safely at death...
Bill..track head
alley cat is offline   Reply With Quote
Old 04-22-2004, 06:36 PM   #5
baroines
Postwhore Meter
PPD:
Bike: Black ZX-10R
baroines will become famous soon enough
Send a message via MSN to baroines
Any suggestions for a 220lb fatdude?
I've used the settings i read somewhere in a magazine on my 12 and the bike is great all the time.
Hopefully my 10R will arrive very soon and I'd like to know your opinions.
baroines is offline   Reply With Quote
Old 04-23-2004, 09:31 PM   #6
kwakman
contributor kwakman's Avatar
Postwhore Meter
PPD:
Bike: Triumph Daytona 675
kwakman is on a distinguished road
I weigh 175 with all my gear, and I backed all the settings as far back as they would go, both fr and rear compression, fr and rear rebound and fr and rear spring preload, and now it is great. When I go to the track I start with setting the preload to the perfect 3/4 sag (which isn't too much) then add 3 clicks to rebound and two clicks compression to start with.
Then adjust from there, some courses will require more compression or whatever, if I don't bottom out, compression is good. Rebound takes trial and error click here, there, out whatever.
hope that might help, but as far as being on the street, kawi's feel best for me backed completely off, and is still stiff enough to hit that occasional clover leaf and smoke a puck especially the oyster point clover right Johnny!
__________________
If you are not smoking your pucks and scuffing your sidewalls, you are just not livin'!!!
Kwak
kwakman is offline   Reply With Quote
Old 04-23-2004, 11:53 PM   #7
mad kaw
mad kaw's Avatar
Postwhore Meter
PPD:
mad kaw has a little shameless behaviour in the past
SR backed the the shock's compression out 5.5 turns. The limit is 4. That adjuster is largely cosmetic. A new rear shock is the hot tip. Ohlins might be all you can get now. They kinda suck as delivered but the three way is useable. The front end feels fine.
mad kaw is offline   Reply With Quote
Old 04-24-2004, 02:00 AM   #8
a
a's Avatar
Postwhore Meter
PPD:
a is on a distinguished road
I asked Andrew T. from SR bout their setings and they were happy with comp. at back on full soft that is 5.5 turns out. They also had backed of preload at back to get 5mm free sag and to come 22mm thread showing. I had 20mm preload on back from factory so i put more preload to get 22mm. But since they put setings on SR shotout they only changed front preload and now is 4lines showing and not 2 lines as they sugested in SR. I have my setings dialed in their way and im happy with them . On tuesday i have track day so will see.
__________________
Akrapovic slip on, race screen, champ sliders, steel brake lines,DID 520 chain and sprockets, ohlins shock, race tech steering damper, AIM lap timer and everythin in carbon fiber except tank.
ride it like u stole it
a is offline   Reply With Quote
You may not post replies
Forum Jump
Powered by: vBulletin Version 3.7.3
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2003-2012 ZX-10R.net
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
