Gen 4: 2011- Rifleman's 1/5th throttle installed! Quick & easy. - Kawasaki ZX-10R.net
Index Index Store Gallery UserCP Memberlist Calendar NewPosts
Go Back   Kawasaki ZX-10R.net > General Discussions > The ZX-10R
Thread Tools Display Modes
Old 05-09-2012, 10:55 PM   #1
teedub21
teedub21's Avatar
Postwhore Meter
PPD:
teedub21 will become famous soon enoughteedub21 will become famous soon enough
For those of you with a Gen4 considering this mod, do it, its easy! It seriously took me all of 10 minutes to install this part. The throttle housing on the Gen4 is plastic, not metal like the previous gens so the two tabs are easy to dremel out. I was able to back the adjustments all the way out on the throttle side and it gave me enough slack, didn't have to touch the throttle body side! The throttle snaps back, just like stock. There is no slack what so ever in the throttle right now, which is how I like it. Turning the bars lock to lock idle doesn't change so I'm fine. For some reason, the throttle has a more "solid" feel than it did stock, not sure why this would be.
As far as the effect of this mod? Damn, it doesn't take much to crank on the speed! I wouldn't say its touchy, but definitely exercise some caution until you get used to it!
__________________
teedub21 is offline   Reply With Quote
Old 05-10-2012, 01:29 AM   #2
Interceptin
Interceptin's Avatar
Postwhore Meter
PPD:
Bike: 11 Black/Red ZX10R
Interceptin is on a distinguished road
It's all in the wrist buddy, 1/5th is a cool mod but ill stick to my factory housing since one of my friends got stuck and almost died.
Interceptin is offline   Reply With Quote
Old 05-10-2012, 01:33 AM   #3
BigCat10R
BigCat for Prez!
contributor BigCat10R's Avatar
Postwhore Meter
PPD:
Bike: THE BigCat
BigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant futureBigCat10R has a brilliant future
didnt install it right...gotta test it in neutral first to check for throttle stick, then do the same with the handlebars cocked in both directions. Mine stuck at first bec it needed the accelerator cable adjuster cut down like in the intructions
__________________
I Have an 8-12 evil arm for sale
BigCat10R is online now   Reply With Quote
Old 05-10-2012, 02:13 AM   #4
neverendingmods
Gen2 Ripper
neverendingmods's Avatar
Postwhore Meter
PPD:
Bike: Lime Green ZX-10R
neverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud of
Mine on gen2 simply took just adjusting first set of adjusters in all the way like op.
Gotta make sure when you reassemble the housing that the cable is in place on underside. Real easy to overlook that and than I could see throttle sticking. But if you take your time and di it right it can be installed and running in 30 minutes including grinding.
I never should have waited so long. I was creating a bar wag by extending my wrist and arm trying to go WOT stock. Now ny arm barely moves. Great cheap mod and for anybody that drag races they know what a tenth of a second equals at the finish line.
__________________
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline   Reply With Quote
Old 05-10-2012, 09:35 AM   #5
teedub21
teedub21's Avatar
Postwhore Meter
PPD:
It really is simple, not sure how you could mess it up. When I first assembled it I could hear the cables binding and it sounded rough. Took it apart and I don't think I had the cables in place over the cam. Re-assembled it taking my time and made sure to test it a few times. I knew I had it right the second time because it was smooth as can be and snapped back to closed. Took it for a quick ride just remembering to cover the clutch and the kill switch "just in case". Didn't actually check the "lock to lock" steering to see if the idle sped up until I got home, but all was fine. It is pretty basic, I don't know how you could mess it up. If it doesn't feel "right" when you're done then you probably didn't put it back together the correct way.
__________________
Old 05-10-2012, 09:38 AM   #6
bgmagma10
Slow Poke
contributor bgmagma10's Avatar
Postwhore Meter
PPD:
Bike: 05 Magma 10R
bgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant future
lol thats what the kill switch is for
__________________
bgmagma10 is offline   Reply With Quote
Old 05-10-2012, 12:00 PM   #7
Interceptin
Postwhore Meter
PPD:
Yeah good thing it got stuck when he was hitting the straight away. It got stuck randomly, it was fine for months. All of a sudden it took a shit. He did mention he rushed the process of doing it. This is a great mod don't get me wrong.
Old 05-25-2012, 08:25 AM   #8
timbo1083
timbo1083's Avatar
Postwhore Meter
PPD:
Bike: Metallic Black Spark ZX-10R
timbo1083 is on a distinguished road
Just installed. Literally took 10 min after reading a post. And.. for some reason it made it quieter too? I know it wasn't a valve knocking, it was just Kawa's in general. But now it sounds fine. Interesting.
timbo1083 is offline   Reply With Quote
Old 05-25-2012, 12:55 PM   #9
Quantum
Quantum's Avatar
Postwhore Meter
PPD:
Bike: 2012 10R green. Track: 2011 10R green/black glass
Quantum has a spectacular aura aboutQuantum has a spectacular aura aboutQuantum has a spectacular aura about
Originally Posted by timbo1083 View Post
Just installed. ... And.. for some reason it made it quieter too? I know it wasn't a valve knocking, it was just Kawa's in general. But now it sounds fine. Interesting.
Probably the cam chain tensioner self adjusting. Read: http://www.zx-10r.net/forum/showthread.php?t=101967.
Take it easy, respect your new "Gen 4 learner" and seriously consider URBAN LEGEND's good advice.
__________________
Street: Unrestricted ECU (+ Ivan's wire mod... removed) | -1 +1 | Bazzaz QS4 USB | APE CCT | 1/5th throttle insert | re-valved SD | ZG DB screen | Spiegler SS lines | TechSpec tank grips & pad | LSL sliders | Carbonadi case covers | R&G tail tidy | R&G Tank Sliders | 55W HID low / +120% xenon high | OzzieMoto radiator protector | the2wheels levers...
Track: Most of the above plus: Doctor Glass fairings | Leo Vince with link pipe| Bazzaz ZFI-QS| Hell's servo eliminator | 520 chain -1, +1 ...
Quantum is offline   Reply With Quote
Old 05-25-2012, 08:32 PM   #10
timbo1083
timbo1083's Avatar
Postwhore Meter
PPD:
Feels amazing now. Best mod ever
You may not post replies
Forum Jump
Powered by: vBulletin Version 3.7.3
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2003-2012 ZX-10R.net
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
