05-01-2012, 04:38 PM
#1
Bike: Ebony Black ZX-10R
Octane choices
I understand that these bikes r super sport bikes and need the best of everything but y can't we use 87 octane??? Some say it doesn't hurt anything others say it does. I always put 93. But ive seen others put 87. Elaborate
05-01-2012, 04:42 PM
#2
Bike: 05 zx10R
I heard the same thing as you. Just to try it out the last 2 tanks of gas on my bike have been 89. I don't push the bike hard, 90% of my riding is done under 7k rpm. I took the bike out to some back roads with friends over the weekend and I couldn't feel any difference in the bike from 91 to 89. I had my bike tuned on 91 it doesn't have much work just a slip on K&N and PC3.
05-01-2012, 04:44 PM
#3
Slow Poke
Bike: 05 Magma 10R
With a stock motor Using 87 is completely fine, it actually makes more power, They say to use higher octane to fight detonation, but with a stock motor it would take some seriously extreme conditions to detonate. I've ran 87 in my bike for years without a single problem. 87 octane burns hotter, therefore makes more power..
05-01-2012, 04:50 PM
#4
Bike: 05 zx10R
Seeing your post in another thread got me wanting to try a lower octane. I'm so paranoid about octane thanks to my RX-7 days where you get some knock (pre detonation) and your motor is gone.
05-01-2012, 04:54 PM
#5
Super Moderator
I've only ever heard mine ping if I bogged it off a start, and then only for a moment.
The factory specs are for worst case conditions: High ambient temperature, hot coolant temperature (120 C), low altitude, engine being lugged down under load, plus a margin of safety.
__________________
#6
Super Moderator
__________________
05-01-2012, 04:57 PM
#7
Bike: 05 titanium
I only get 93 from shell it is supposed to have an additive that cleans the valves.
__________________
 Its green and it says Kawasaki ninja zx10r on it!
05-01-2012, 04:58 PM
#8
I'm tempted to try it. Save a couple pennies
05-01-2012, 05:00 PM
#9
Bike: 2012 10R green. Track: 2011 10R green/black glass
Checkout: http://www.zx-10r.net/forum/showthread.php?t=113117 and you may choose not to save a few pennies.
__________________
Street: Unrestricted ECU (+ Ivan's wire mod... removed) | -1 +1 | Bazzaz QS4 USB | APE CCT | 1/5th throttle insert | re-valved SD | ZG DB screen | Spiegler SS lines | TechSpec tank grips & pad | LSL sliders | Carbonadi case covers | R&G tail tidy | R&G Tank Sliders | 55W HID low / +120% xenon high | OzzieMoto radiator protector | the2wheels levers...
Track: Most of the above plus: Doctor Glass fairings | Leo Vince with link pipe| Bazzaz ZFI-QS| Hell's servo eliminator | 520 chain -1, +1 ...
05-01-2012, 05:06 PM
#10
Starbucks Connoisseur
Bike: 2006
Um.. How much would you really be saving on a 4.5 gallon tank?
If you usually fill up about 3-4 gallons and 87 being $0.2 cheaper than 91, that's like around $.5 and filling up twice a week you'd save like $4-5 per month. You'd barely save enough each month to buy a Venti Mocha Latte for $4.35
__________________
08' Standard Drip
09' Ice Blended Peppermint Mocha Frappuccino
10' Venti Mocha Latte spilled some of it, was too hot
11' Peppermint Mocha W/Extra Shot of Espresso
12' Eggnog Venti Latte
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
You may not post replies
