Gen 4: 2011- Pretty disappointed in whp on the dyno - Kawasaki ZX-10R.net
Index Index Store Gallery UserCP Memberlist Calendar NewPosts
Go Back   Kawasaki ZX-10R.net > General Discussions > Performance and Tech
Thread Tools Display Modes
Old 04-19-2012, 11:08 PM   #1
Interceptin
Interceptin's Avatar
Postwhore Meter
PPD:
Bike: 11 Black/Red ZX10R
Interceptin is on a distinguished road
Stock dyno power is correct at 155-157.
Not sure what went wrong but put the bike on the dyno on bike night and saw low whp for a stock zx10r... It looks very good til the bike got rich around 9-13k. Drop about a quarter inch from there. I knew it was rich after i put the link pipe but the if we clean the afr, it would only still be in the 159-162. Wanted to know what ya inputs are?
Made 156 whp both pulls, they check the drums and still did the same. Shot some flames when WOT was off. My old 09 made 163 on a slip on and pcv.
Specs:
1400 miles, conventional oil. Changing tomorrow.
Leo vince slip on evo R with link pipe.
1500ft, 79 temp
TC off and it was on F.
Upgrades: Sending the ECU off and PCV with BMC filter.
Interceptin is offline   Reply With Quote
Old 04-19-2012, 11:18 PM   #2
barnes
barnes's Avatar
Postwhore Meter
PPD:
Bike: Lime Green ZX-10R
barnes is an unknown quantity at this point
Send a message via MSN to barnes
What was your A/F on the dyno runs?
__________________
Design by a genius, Built by a craftsman, Ridden by a twat....
“See God. Then back off” Kevin Schwantz on his late braking technique.
barnes is online now   Reply With Quote
Old 04-20-2012, 01:31 AM   #3
Volzx10r
Volzx10r's Avatar
Postwhore Meter
PPD:
Bike: 2011 Green ZX 10R ABS
Volzx10r is a jewel in the roughVolzx10r is a jewel in the roughVolzx10r is a jewel in the rough
Was the CF on the dyno SAE or STD?
Volzx10r is offline   Reply With Quote
Old 04-20-2012, 01:13 PM   #4
Interceptin
Postwhore Meter
PPD:
The afr was perfect til 9k it dropped 1 afr off .
I'll look into that today when he sends the sheet.
Old 04-20-2012, 01:18 PM   #5
rafa
Squid wannabe
rafa's Avatar
Postwhore Meter
PPD:
rafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant futurerafa has a brilliant future
What does this mean?
And it doesnt sound to far off for a bike with no reflash.
This is around what my 1st gen made with a full exhaust and downloaded map.
__________________
"The ZX-10R is capable of being perfectly docile and tractable, but few men are capable of resisting its ever-present voice urging them to just twist it and see what happens."
rafa is offline   Reply With Quote
Old 04-20-2012, 01:31 PM   #6
bgmagma10
Slow Poke
contributor bgmagma10's Avatar
Postwhore Meter
PPD:
Bike: 05 Magma 10R
bgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant futurebgmagma10 has a brilliant future
What do you mean by perfect?? What was it? You really can't say what a perfect afr is. Each bike is different.. Some make more power a little leaner and some make power a little richer.. Plus bike temp makes a difference too. My bike makes best power right at 200 drgrees, but I watched an R1 came in the other day that made best power at like 160. So a lot of variables to think about.
What i'm guessin he means is more or less went from say 13.2.1 and maybe dropped to 12.2.1??? I hope it wouldn't drop that far in a few k rpm's but who knows..
__________________
bgmagma10 is offline   Reply With Quote
Old 04-20-2012, 03:13 PM   #7
ZX10RArcher
Postwhore Meter
PPD:
Bike: 2011 ZX-10R ABS
ZX10RArcher is on a distinguished road
And when you say "sent the ECU off"... to whom? Guhl? Dynotronics? ECU Unleashed?
ZX10RArcher is offline   Reply With Quote
Old 04-20-2012, 03:19 PM   #8
cyclepuck
contributor cyclepuck's Avatar
Postwhore Meter
PPD:
Bike: 74 CB200 cafe project
cyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud of
What were other bikes making on that same dyno?
Sent from my DROID2 using Motorcycle.com Free App
cyclepuck is online now   Reply With Quote
Old 04-20-2012, 03:33 PM   #9
WildB302
contributor WildB302's Avatar
Postwhore Meter
PPD:
Bike: The Beast. 2004 Green ZX10R
WildB302 has a spectacular aura aboutWildB302 has a spectacular aura aboutWildB302 has a spectacular aura about
That sounds about right. U shouldn't expect much more in stock ish trim. Every Dyno can be very different. Even every bike can be a little different stock to stock from the factory.
Std corrections will give you 4% higher HP reading vs SAE correction.
Maybe your ten was made on a Friday. The fastest ones are made on Tuesday.
__________________
08 race cam, KibbleWhite springs, tit. retainers, thin HG, short velocity stacks, removed secondaries, bmc filter, full Akra Evo cut 5in, power com., ignition module w/rev xtend, dyno tune, speedo healer, 16,17, and 40,42 520 sprockets, vortex rearsets (gp shift), pazzo levers, galfer lines, ZX14 calipers, shorai batt, carbon front fender, gpr stabalizer, puig screen, gilles chain adjs., 1/5 throttle, Kleen air mod, Crankcase sucker mod, O.Z. wheels, 408lbs full of gas.
WildB302 is offline   Reply With Quote
Old 04-20-2012, 04:08 PM   #10
JLove
JLove's Avatar
Postwhore Meter
PPD:
Bike: Black ZX-10R
JLove will become famous soon enoughJLove will become famous soon enough
With a pipe and filter I made 182. Getting flashed this week and will re-dyno.
__________________
2004 ZX-10R black (sold)
2008 CBR1000RR
2011 ZX-10R ABS Black
#51 NESBA, TPM, Absolute
JLove is offline   Reply With Quote
You may not post replies
Forum Jump
Powered by: vBulletin Version 3.7.3
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2003-2012 ZX-10R.net
Motorcycle News, Videos and Reviews
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
