02-14-2012, 11:13 AM
#11
Bike: 2006 ZX-10R
TRE = Timing Retard Eliminator
Supposedly, the timing is backed up a few degrees in the first 4 lower gears. A TRE fools the ECU into thinking you are always in 4rth gear. Note that if you have a gear indicator, the TRE may interfere with it.
You can get a cheap one from fleebay for $30. This is the route I went with. Didn't notice much of a difference, its one of those mods that adds a little and is best used in conjunction with other mods, such as a power commander with slip-on cans.
02-14-2012, 02:09 PM
#12
Bike: green 05 ZX10R
This totally baffles me...I have a bone stock (in engine and exhaust) 05 and live where the roads are steep grades/blind, tight switchbacks, and my bike has the sweetest inital and beyond throttle, there is.
The bike is also rock solid/stable...It always was...and still is...I changed the handle bars to street fighter, and installed Scotts Stabilizer/Damper...had Race Tech do total conversion of shimstacks, & springs for the rough roads here, steepened my forks for quicker/easier line picking and holding...No loss of stability what-so-ever came with that.
02-14-2012, 06:56 PM
#13
Can you further clarify the symptoms?
Are you talking about a definite misfire, where you feel a sudden and harsh miss, or is just running a little rough down there?
What is the typical throttle position when you experience this symptom?
What is your elevation?
My bike is a little jerky at low revs (under 4k rpm) and light throttle in 1st and 2nd. The momentum of the bike probably masks the symptoms in higher gears at those revs.
My guess on the limited info available is a fueling issue, and this would be corrected by a tune (Power Commander required, of course). I think someone else suggested the same.
02-14-2012, 07:19 PM
#14
Bike: Green ZX-10R
Fuel pump ???
Clogged fuel filter ???
02-14-2012, 07:24 PM
#15
Bike: 05 Lime Green ZX-10R
To be honest it sounds exactly like my bike back when I had a slip on and no tune.
__________________
Originally Posted by NinjeR
I'm glad I'm a stripper, the money keeps coming in! lol
02-14-2012, 07:28 PM
#16
Bike: Pearl Solar Yellow ZX-10R
To me it sounds like you're not used to a bike with retarded timing in the low rpms.. and a TRE would fix it right up for you.
After i installed my tre i noticed a huge difference <4k rpms
__________________
Two bros exhaust, pcIII, 16t front 42t rear, 1/5 throttle, ivans TRE, HID's,white LED running lights, complete underglow LED's, speedohealer, flies removed, nissins with ss lines, k&n filter
Originally Posted by Guyta
Fuck that's hot, i wish god didn't make me ugly.
02-14-2012, 07:39 PM
#17
Originally Posted by ninja_12r2000
Fuel pump ???
Symptoms would persist or be worse at high RPM and wide open throttle. Doesn't seem to be the case.
02-14-2012, 09:09 PM
#18
Bike: 2011 Arctic White ABS
Have you checked throttle body sync?
__________________
ZX14 cam chain tensioner making noise? I have the set it and forget it fix. PM me if I can help.
02-14-2012, 10:45 PM
#19
You say fuel pump are ok n not blog. Maybe u should check if the pump pressure is right, .
02-15-2012, 12:26 AM
#20
Bike: Black Gen4
I was reading Lee Parks Total Control and he says a lot of bikes come from the factory with the throttle bodies out of sync. Don't know how much of that is proven out and the book was published in 2003, so take it with a grain of salt, But, May be something to check...
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
You may not post replies
