Last chance to cure the Gen 1.... - Kawasaki ZX-10R.net
Index Index Store Gallery UserCP Memberlist Calendar NewPosts
Go Back   Kawasaki ZX-10R.net > General Discussions > The ZX-10R
Thread Tools Display Modes
Old 02-13-2012, 09:07 AM   #1
scott22neale
scott22neale's Avatar
Postwhore Meter
PPD:
Bike: Lime Green ZX-10R
scott22neale is on a distinguished road
Ok all. At the end of the tether trying to fix my gen 1 Its had this problem from when I bought it with 1700 miles on, it now has 7333 miles on. Long story short, the seller cried ignorance when I went back to him, the bike has had 2 full services in the time I had it and was serviced before I got it.
It has a misfire/rough running at low rpm, (about 1500 - 2500). Basically when riding through towns, pulling away from juntions/lights or riding at low revs up inclines etc (like this big 1 mile hill I live up... !!!) it jerks and misses?? If you pull the clutch in it clears up, and if you open the throttle it clears up. It responds/picks up immediately every time if you crack the throttle and there are no power losses anywhere else and runs sweet...
There are no FI codes up, and heres what I've checked already -
*Plugs have been changed twice for new ones, and the old ones checked in another bike and they were fine.
* Coils checked and swapped, all fine.
* Checked camshaft/crankshaft/inlet/temperature and other sensors
* No vacuum leaks
* Fuel pump checked and filter - all ok
* Tank drained and cleaned twice - all ok
* Side stand switch checked and tested ok
* Throttle checked by bike mechanic and said ok
* Connectors checked and contact sprayed
* Injectors cleaned and ok
* Seafoam run through the system
* Exhaust system and exhaust servo checked - all ok
* Done the water on the header pipe test, all heat up the same at same speed.
* ECU connector pins all checked - ok
* New battery
* Battery terminals all screwed down and ok
* Airbox seals ok, all breather pipes ok and not restricted
* No perished pipes/connections
May have checked one or two other things, its hard to remember them all ! Am I missing something obvious ??? Im coming down to the point where Im wondering whether its fueling that is incorrect maybe due a dodgy ECU ? I really am at wits end !!!! I love the bike and really want to fix it, but getting so dishearted Im giving it one more shot then trade it
Cheers all
The bikes Mods are, racefit end can and K&N filter (but I had the same problem with the stock can and stock filter just as bad).
scott22neale is offline   Reply With Quote
Old 02-13-2012, 09:12 AM   #2
scott22neale
Postwhore Meter
PPD:
Forgot to say
I also checked the FI code system to make sure it works by disconnecting the airbox sensor and it threw a code at me so it is working ok.
Old 02-13-2012, 09:15 AM   #3
cyclepuck
contributor cyclepuck's Avatar
Postwhore Meter
PPD:
Bike: 74 CB200 cafe project
cyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud ofcyclepuck has much to be proud of
Do you have a pc on it? Check chain for kinks sometimes that will give a funny feeling. Is it backfiring? Goes away when clutch pulled maybe pull cover see if anything obvious in there.
cyclepuck is online now   Reply With Quote
Old 02-13-2012, 11:03 AM   #4
neverendingmods
Gen2 Ripper
neverendingmods's Avatar
Postwhore Meter
PPD:
neverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud ofneverendingmods has much to be proud of
Are the secondary throttle body butterflies still in it?
__________________
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline   Reply With Quote
Old 02-13-2012, 11:13 AM   #5
GreenWeenie
GreenWeenie's Avatar
Postwhore Meter
PPD:
Bike: Green 05, Red/Black 2012
GreenWeenie will become famous soon enough
If its the stock exhaust can, they can melt inside and plug themselves up.
Try a different exhaust can.....
__________________
02 998 Mono - Garage Queen
08 1098S Race - RIP
04 ZX10R Orange - SOLD
04 ZX10R Black - SOLD
05 ZX10R Green- Race- Blowed Up!
04 ZX10R Black- SOLD
05 ZX10R Green- Blowed Up!
05 ZX10R Green - FOR SALE!
2012 ZX10R Red/Black- Street
04 Z71 Avalanche
78 Corvette Indy Pace Car
63 340/327 Corvette Roadster
OMRRA #69
GreenWeenie is offline   Reply With Quote
Old 02-13-2012, 12:21 PM   #6
my10r
my10r's Avatar
Postwhore Meter
PPD:
Bike: gen 3 greeny
my10r is on a distinguished road
have you checked that there isnt a TRE fitted. as they can make it stuttery between 1200-2000
__________________
fallen ones are not forgotten
www.youtube.com/user/my10r
my10r is offline   Reply With Quote
Old 02-13-2012, 04:47 PM   #7
Johns04ZX10R
Johns04ZX10R's Avatar
Postwhore Meter
PPD:
Bike: Black 04 ZX10R
Johns04ZX10R is a jewel in the roughJohns04ZX10R is a jewel in the roughJohns04ZX10R is a jewel in the rough
get a power commander and go to the dyno and tune it out
Johns04ZX10R is offline   Reply With Quote
Old 02-14-2012, 02:52 AM   #8
scott22neale
Postwhore Meter
PPD:
Cheers
Cheers all for your responses ! Umm, I havent got a PC yet but I was looking in to one to see if this prob could be dialed out with a custom map. It does have the secondary butterflies in still, would removing them help (or help in another way? ) Ive tried a different can from stock with the racefit :( The chain is ok, no kinks or slack As for the TRE, Im not sure, where would it be? As far as I know it was total stock when I bought it
Old 02-14-2012, 03:32 AM   #9
neverendingmods
Gen2 Ripper
Postwhore Meter
PPD:
The butterflies being in was an issue for alot of Gen1 owners. Maybe more can chime in on the subject.
Just to make sure..are you POSITIVE you are not just bogging the bike? I mean keeping the RPM's too low by being in too high a gear. These bikes don't wake up until 4k rpm atleast. If the bike has after market exhaust or air filter or any kind of TRE etc, it will really Benefit from a custom dyno tune to get the rideability perfect after any kind of performance mod.
__________________
07-ZX10R-SOLD
05-ZRX1200R-sold
04-KX500-sold
Old 02-14-2012, 06:38 AM   #10
scott22neale
Postwhore Meter
PPD:
Cheers
Thanks for the reply dude ! I will look in to the butterfly issue more Definitely not bogging, it does it in first gear when you pull away, that said when Im going through towns/slow areas etc, I now keep it in first which keeps the revs out of the danger zone and gets around it. Is weird though as other 1K bikes ive had have been happy to trundle through in second gear at the same revs
Ok Im going to sound like a right newbie here but, where can I get a TRE, and what do they do ???
You may not post replies
Forum Jump
Powered by: vBulletin Version 3.7.3
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2003-2012 ZX-10R.net
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
