Originally Posted by waco408
Is the 09 int cam the same as the 08 int cam? If so can't I run this in a 06 and it is a upgrade over the 06 cam ?
Yup, they are the same cam. And it will work with the Gen1 but you will to have mismatch either the cam gears or mounting bolts for the cams.
__________________
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
