Originally Posted by abzx10r
To may factors come into play with pressure. Road,conditions,you etc etc!
You can play in the 20's to the low 30's if you ride! Just keep in mind you can have weird tearing if you can't ride or have a bad suspension setup...not to mention your tires will get eaten
temps are bewteen 16 and 22 degrees at the moment in the u.k
the roads are mostly smooth here!
my suspension has been done by K-TECH a leading suspension company in the u.k but it was setup for the previous owner for track, he was 18st!!
the bike still seems to work for me althaugh i would prefer a little less preload on the rear!!!
im going to try 30 32 as the last owner recommended and see where we go, just for the record the manual pressures are 36 42.
thankyou for the reply, mark
