What's causing this..? - Kawasaki ZX-10R.net
post #1 of 4 Old 03-17-2017, 03:05 PM Thread Starter
formerly GHOST RIDER
SOUN1's Avatar
Its from my track bike: 05 ZX6R symptoms: can't get the clutch cable tight, the bike grabs and release (jerking motion) @ 2nd. gear high rpm( coming out of a corner).. does this in 2nd. gear only..
Normal track riding style.. clutchless shifting ... clutch fibers are new.. if it's transmission issue then the bike is gone...not dealing with engine problem.. Any help is greatly appreciate it!!
Never forget who helped you!
Never forgive who fu*ked you.
Doing a trackday is like "SEX", no matter what happens you'll want to hit it again..
SOUN1 is offline
post #2 of 4 Old 03-17-2017, 08:28 PM
dharmon012's Avatar
i had a 98 zx6r that would do that, would also clutchless upshift. found i had worn gears and bent shift forks. kind of made it buck in second gear...pretty violently
fixed it with my dad for a couple hundred bucks but it involved dropping the motor and splitting the cases
15 ZX10R
91 Harley Fatboy
04 ZX10R - Burned in front of my eyes
00 R1 - Stolen & Crashed
98 ZX6R - SOLD
dharmon012 is offline
post #3 of 4 Old 03-18-2017, 09:53 AM
With regards to your new clutch fibers, did you measure clutch stack height? You did use oem fibers, right?
rcannon is offline
post #4 of 4 Old 03-21-2017, 10:39 AM Thread Starter
SOUN1's Avatar
dharmon012, if that's the case I'm done with it... I'll replace the motor or look for a new bike, such a shame because I got spare parts for it..
rcannon, Yes.. the fiber are OEM.. rode the bike for a couple of track days before having the issue..
If worst comes to worst...I'll take my gen. 1 out to the track...
SOUN1 is offline
