Oil filter for the 2016 - Kawasaki ZX-10R.net
 6Likes
post #1 of 53 Old 01-19-2016, 11:03 PM Thread Starter
g-man's Avatar
Can someone tell me if the new 2016 model takes the same filter as the 2015? I need to order some K&N filters. The '15 took a KN-303.
g-man is offline
post #2 of 53 Old 01-20-2016, 06:19 AM
dricked's Avatar
I would recommend using oem mainly because the bike is under warranty and if something were to happen that was oil related they're going to point right at that filter. The oem ones aren't anymore expensive.
I also had a k+n filter try to kill me but that's another story.
turtle1000 likes this.
dricked is offline
post #3 of 53 Old 01-20-2016, 08:03 AM Thread Starter
g-man's Avatar
Thanks, I like the K&N's as they are drilled for safety wire.
If there was an issue, I could always slap an OEM back on it
g-man is offline
post #4 of 53 Old 01-20-2016, 08:43 AM
evilaugust's Avatar
Don't leave us hanging bro.
evilaugust is offline
post #5 of 53 Old 01-20-2016, 08:46 AM
dricked's Avatar
O-ring blew out, filled my belly pan with oil down the back straight. Rode through the run off area but if it were on the road...
dricked is offline
post #6 of 53 Old 01-20-2016, 08:47 AM Thread Starter
g-man's Avatar
If you guys are safety wiring with the OEM, would love to see how/where the connection is.
g-man is offline
post #7 of 53 Old 01-20-2016, 08:50 AM
tdh
tdh's Avatar
Just use a hose clamp around an OEM filter and attach one end of the safety wire to the hose clamp.
tdh is offline
post #8 of 53 Old 01-20-2016, 08:52 AM Thread Starter
g-man's Avatar
No, that's the way I do it now with the Gixxer, I was wondering where you connect the other end of the wire.
g-man is offline
post #9 of 53 Old 01-20-2016, 08:54 AM
tdh
tdh's Avatar
Oh sorry. I drill a hole in an oil pan bolt and wire to that (if I recall, without going out in the garage and looking). :)
tdh is offline
post #10 of 53 Old 01-20-2016, 08:55 AM
dricked's Avatar
There's a lip on the casting for the oil pan. I drilled a small hole there
dricked is offline
