Injector cleaner? - Kawasaki ZX-10R.net
post #1 of 10 Old 02-26-2017, 10:30 PM Thread Starter
JepoyDaNinja's Avatar
Injector cleaner?
Is it okay to use fuel injector cleaners on bikes? Thanks!
JepoyDaNinja is offline
post #2 of 10 Old 02-27-2017, 01:05 AM
Use SeaFoam, absolutely acceptable.
Gen-Eric is offline
post #3 of 10 Old 03-01-2017, 12:04 PM Thread Starter
Thanks thanks! Added seafoam yesterday and kept the rpm near redline for a 15 mins ride. Started my bike today and the idle seems to have gone better.
post #4 of 10 Old 03-01-2017, 12:28 PM
Capncalyx's Avatar
lol
Edit - Actually, i do that when i lube my chain on the stand.
*Official winner of one Riflemans 1/5 insert
"Stop being such a Sheila, Peter" - Peter's Dad
Capncalyx is offline
post #5 of 10 Old 03-02-2017, 08:49 PM
The Pace
scout's Avatar
amsoil as that cleaner. I've used seafoam in past, np's.
scout is offline
post #6 of 10 Old 03-08-2017, 03:04 AM
Post Whore
-Op-'s Avatar
Used seafoam too. Works fine. Just make sure you scale it based on tank size according to the instructions on the bottle.
-Op- is online now
post #7 of 10 Old 03-08-2017, 01:16 PM
Porschenut's Avatar
What's the easiest place to insert the Seafoam tube? I'm guess it's downstream from the airbox but that means removing the tank and reinstalling it again? Is there an easier way?
Cheers
Porschenut is offline
post #8 of 10 Old 03-09-2017, 12:48 AM
Post Whore
-Op-'s Avatar
I just poured it in the filler cap into the tank.
-Op- is online now
post #9 of 10 Old 03-09-2017, 07:36 AM
Cheers
Two different types of seafoam. The type you're referring to is a mist injected down the intake manifold for cleaning piston crowns and the type poured into the tank is more for injectors. But the answer, I believe, would be no there is no easier way to use that product to clean carbon from the pistons. It has to be applied through the intake and it cannot go through the air filter first.
Kllongbrake is offline
post #10 of 10 Old 03-11-2017, 01:46 AM
Near redline was completely unnecessary, and stupid for 15 minutes on a good bike let alone yours. Sure it handled it but most certainly you did more harm then good.
Gen-Eric is offline
