Gen 4: 2011-2015 HRC rear brake reservoir - Kawasaki ZX-10R.net
 14Likes
post #1 of 21 Old 07-25-2017, 02:38 AM Thread Starter
peterd10r's Avatar
Images: 7
This would have to be the most expensive piece of tubing Ive ever purchased Click image for larger version
Sent from my iPad using Tapatalk
rcannon and Helitech like this.
peterd10r is offline
post #2 of 21 Old 07-25-2017, 09:52 AM
Helitech's Avatar
Originally Posted by peterd10r View Post
This would have to be the most expensive piece of tubing Ive ever purchased Attachment 402914
Hahaha I thought about it, but why couldn't you just use something similar? How much did it run you brother? Younjust keep adding to my list don't you?
Helitech is offline
post #3 of 21 Old 07-25-2017, 09:54 AM
Helitech's Avatar
By the way, that BEET pipe is coloring nicely!!!
Helitech is offline
post #4 of 21 Old 07-25-2017, 12:07 PM
Capncalyx's Avatar
Yes, but technically i think they supplied ya with enough to possibly do both bikes should you have two and maybe rig up an extra clamp or two from the garage. Gonna get one myself when i have piss away $$. I, like you, enjoy trying to drop every ounce off my bike. Looking at your bike reminds me i need to wash mine! Love the tricky bits on that bike Pete!
*Official winner of one Riflemans 1/5 insert
Every fortress falls, it is not the end. It aint if you fall, its how you rise that says who you really are.
- QOTSA
"if you want to be told today to fk off let me no I can help"
- Peter
Capncalyx is offline
post #5 of 21 Old 07-25-2017, 12:20 PM
LDH
LDH's Avatar
The problem with HRC tubing is that it sweats brake fluid. It literally is semi-permeable tubing that lets the fluid seep out of microscopic pores in the tubing and it will continue to do so until it gets old and brittle and then doesn't work properly at all. Back when all the HRC bikes used it the first things a technician did when handling the bike would be to wipe the tubing with the rag they always had in their hands...
Most people don't realize it, but brake fluid reservoirs are vented which is how they get moisture into the hygroscopic brake fluid which in turn requires the fluid to be changed at regular intervals to retain its effectiveness. The water absorbed into the fluid can be turned into vapor with excessive heat and then you get the dreaded brake fade we have all experienced. When you use a kit like that with a solid plug it can create pressure issues and improper operation of the braking system if not maintained attentively. Granted the rear is generally used a lot less than the front, but it can certainly happen.
Tygon tubing is a much better choice for that type of reservoir.
LDH is offline
post #6 of 21 Old 07-25-2017, 02:37 PM Thread Starter
peterd10r's Avatar
Images: 7
I actually new the oem was vented LDH and when it arrived I thought it might have a tiny pin hole but no it's solid!I thought it was Tygon tubing that's why I purchased it but I will check that out!and Captncalyx I already have cut 35mm of that long mofo already lol!and thanks for the compliment also
Capncalyx likes this.
post #7 of 21 Old 07-25-2017, 02:39 PM Thread Starter
peterd10r's Avatar
Images: 7
I think it was $25aus Helitech lol
post #8 of 21 Old 07-25-2017, 02:58 PM Thread Starter
peterd10r's Avatar
Images: 7
LDH would I have any issues running a vented type plug for the top of the tubing!could this create more problems and thanks in advance mate
post #9 of 21 Old 07-25-2017, 03:04 PM
LDH
LDH's Avatar
We used to drill a tiny tiny little hole in the plug for that purpose.
LDH is offline
post #10 of 21 Old 07-25-2017, 03:16 PM Thread Starter
peterd10r's Avatar
Images: 7
Thank you tiny tiny hole to mod my new mod!Im going to use a micro garden sprayer from my garden sprinkler system and blame the dogs!
Helitech likes this.
