Gen 5 zx10r hesitation below 5k rpm - fix? - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 14 Old 07-17-2017, 08:01 PM
I have a gen4 so take it for what it is worth. I am working on this right now with a full Mivv exhaust. My almost perfect graves slip and Leo Vince midpipe tune was way off. To the point of I started over from scratch. I know exactly what you are talking about.
Add some timing-I have 1200 rpm at 17, 1400 at 16.8 and blend in to the cells above. Stock was 10. Idle rpm is set for 1400
These are my suggestions. Set autotune to the same in every cell iap and tps. I chose 13.0. This is to get a smooth fuel curve. Once sorted these numbers can change in the higher rpms
Set everything below 3k to 12.5. My engine likes to idle best at 12.0
Add 20% fuel to every cell below 5k, you can take this out as you log.
Drive it and if it is missing still then do not apply any rich areas from the AT map below the troublesome area. If you have been adding rich areas to the fuel map and missing you have been going the wrong way.
Log at idle while the engine is running and match the fuel delivery numbers between iap and tps. Also once you get a feel of how the engine travels through the iap map and tps map, make sure the fueling in these areas are very close.
Hope that helps some, you need fuel to stop the missing and roughness. Also, the fueling between the iap and tps maps must be very close. Even though iap is predominant below a percentage tps does influence the fueling.
Use the smooth function often.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #12 of 14 Old 07-18-2017, 04:56 AM
Victors's Avatar
I dunno. My g4 will wheelie below 5k. I suspect that you have an actual issue. Fuck these guys bro. Id be at the dealer bitching like crazy.
Try turning traction control off in full power mode in 1st and make a few wot runs. Like i said i can wheelie in 2nd and 3rd at 4k.
Good luck, keep us updated.
2013 10R
2007 650R
2016 10R
Victors is offline
post #13 of 14 Old 07-18-2017, 12:30 PM
IMSTuner's Avatar
I never knew hesitation means you can't wheelie. I would assume he was talking about the bike running smooth.
IMSTuner is offline
post #14 of 14 Old 07-18-2017, 12:56 PM
Do you get when rolling on after a previous roll on?
Roll on...Roll off...Roll on?
If so it could be the fuel cut emissions crap that bikes have had for a while now.
Can be tuned out with a flashed ECU and dyno time...There is a fuel cut table in the ECU I believe.
10Arghh is offline
