GEN 4: How to take off the left side fairing - Kawasaki ZX-10R.net
post #1 of 6 Old 08-16-2017, 03:40 PM Thread Starter
xhonda1991x's Avatar
hello, just seeking help on how to remove the whole left side fairing upper and lower, im replacing the plastic and am new to this bike... thanks for the help
ID:	403633   Click image for larger version
Name:	fairing i need.jpg
xhonda1991x is offline
post #2 of 6 Old 08-16-2017, 04:13 PM
You have to pull the cover off from below the front fairing below the lights. Then you can see some push pins and a bolt/net connector. Also, the larger push pin at the bottom has to come out.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #3 of 6 Old 08-16-2017, 04:17 PM
tdh
tdh's Avatar
Page 15-9 in the service manual.
Service Manuals Permanently Rehosted....Again
tdh is online now
post #4 of 6 Old 08-16-2017, 04:33 PM
Porschenut's Avatar
Start removing the fasteners from the bottom up. Start with the bolt near the left rearset and work your way up and toward the front of the bike. Once all the metal fasteners are removed, move on to the sheltered area beneath the headlight and above the front fender. The black inner fender is secured to the side panel with black plastic pop rivets (3 or 4 of them). Push inwards firmly on the center circle of each pop rivet (I like to use a 3mm allen key) and it'll pop and release. At this point the entire side panel (along with the matte black trim piece) should be loose but still connected by fragile tabs that interlock with the middle side panel above the one you're trying to remove. Carefully start with the intersecting corner below your left knee. You'll notice that there's a small tab that inserts from 1 panel to the other. The other tabs are along the top edge and they all hook from 1 panel to the other. Work your way towards the front of the bike and the last tab will be part of the matter trim piece underneath the headlight.
That's my best explanation. Very confusing, but hopefully it all makes sense when you're looking that parts.
Porschenut is offline
post #5 of 6 Old 08-16-2017, 04:38 PM
Porschenut's Avatar
Oh, it looks like you've circled a combination of both the lower side panel, the matte plastic trim piece as well as the middle side panel.
My post above details removal of the lower side panel and trim but not the mid side panel.
To remove the mid side panel the additional steps require removing the windshield, the dash panel (1 bolt, 1 pop-rivet and a plug into a rubber bushing that you can't see on the bottom side of the dash), the mirror and the signal plug.
post #6 of 6 Old 08-16-2017, 04:41 PM
Porschenut's Avatar
If I recall correctly there also a 10mm or 12mm bolt that attaches the mid panel to the headlight. It'll be tucked down low towards the back of the headlight assembly.
