First Mod of your new bike? - Page 2 - Kawasaki ZX-10R.net
 5Likes
post #11 of 18 Old 03-21-2017, 12:19 AM Thread Starter
Originally Posted by blitze View Post
Tires followed by disconnecting exhaust pipe servo.
So much one can do - so little money ))
Tires is also a very good one. I'm cheap so I'll just burn through my stock first while I get used to the bike, then get the set I want. If you are buying a used bike, obviously tread wear will bump this to #1 if it is bad enough, or if the tires are shitty enough. Point here is to be as safe and confident on the bike while "dialing" it in.
That said, chain and sprockets would be my next choice, followed by levers.
So in no particular order for the top 3 at this point would be:
1) Tuning suspension for your body weight, and riding style, environment
2) Tires (same as #1 - riding style, environment)
3) Chain/Sprockets (same as #1 - riding style)
Honorable mentions:
1) Exhaust
2) Levers
3) Chain Adjusters
4) Steel braided brake lines
5) Fender eliminator
6) Turn signals
7) Wind screen
8) Filter
Keep the mods coming, what else do you like to swap out from OEM?
Gen-Eric is offline
post #12 of 18 Old 03-22-2017, 02:22 AM
Nfamous60's Avatar
First mod absolutely frame sliders and for the 2016 zx10r the Trex frame sliders. After that definitely chain sprockets. Fender eliminator or exhaust budget dependent of course.
Nfamous60 is offline
post #13 of 18 Old 03-22-2017, 09:42 AM Thread Starter
F*ck frame sliders, get a full cage and sub-cage. ImpakTech FTW!
Impaktech USA - ImpaktechUSA
Now: Gen-5 ZX10R
Total: 7 Years riding on street. No stunting.
Gen-Eric is offline
post #14 of 18 Old 03-22-2017, 01:38 PM
Nfamous60's Avatar
I dont stunt
post #15 of 18 Old 03-22-2017, 09:22 PM
Post Whore
-Op-'s Avatar
The 10 best parts for the Kawasaki ZX-10R | MCN
Here. I forgot that MCN already polled us before for the top ten mods. Gives ya a good idea.
-Op- is offline
post #16 of 18 Old 03-22-2017, 09:43 PM
Which model?
Hurmann is offline
post #17 of 18 Old 03-23-2017, 07:30 AM
blitze's Avatar
Have to say rearsets are a good investment too. Shifting is much smoother with aftermarket rearsets as is leg position and how your legs feel against the bike.
blitze is offline
post #18 of 18 Old 03-31-2017, 12:49 AM
banzai's Avatar
I start with suspension. It is a big investment and it is better to do it when you get the bike so you have the benefit of riding on good suspension for the duration of ownership. Think of it as amortizing the price over as many years as possible.
I ride country roads at a "spirited" pace and do track days so good suspension is important to me. Dropping $2K-3K on suspension is a lot, but IMHO it is well worth it from a pleasure and safety standpoint. Good tires go without saying. I am a Michelin man. I use their Pilot Powers on the road and their slicks on my racebike.
If you have not ridden a sportbike that is setup with good suspension and dialed in for the rider's weight and riding style, then it is like trying to explain sex to a virgin:)
Brake lines are next if they are of the rubber variety.
'04 Blue ZX-10R, FORKS: Race Tech Gold Valves, .85 KG/mm springs, US1 suspension fluid, Shock: Penske 8900 shock w/8760 compression adjuster, Gilles rear sets and levers, Scotts steering damper, Racefit Mega slip on, Zero Gravity screen, ZX636 Master Cylinder, Galfer Superbike braided brake lines, Vesrah SRJL17 pads, Kawasaki seat cowl, undertail kit, Oury Grips, Valentine One radar detector with Legal Speeding heads-up helmet LED.
banzai is offline
