Gen 4: 2011-2015 cooling fan failure to cut in - Kawasaki ZX-10R.net
post #1 of 12 Old 05-07-2018, 02:19 PM Thread Starter
Keithsebastienzx10r's Avatar
Guys, need inputs regarding my cooling fan failure issue on my zx10r.
Just recently got a 2013 zx10r with 4000km odo very neat, but noticed that coolant temp went to "HI" warning.Did a bit checking on it and noticed that cooling fan does not work, tried to flush coolant and swappped multi function relay from my 2013 z1000 limited but still cooling fan does not work. Another issue was the FI warning, eventually I realized that it could be the battery cause it has not been changed since the first owner.
Hope you guys can give me inputs on what to check next and by the way have'nt brought the unit at kawasaki service center yet for diagnosis.
Thanks guys...
Keithsebastienzx10r is offline
post #2 of 12 Old 05-07-2018, 04:02 PM
SkyDork's Avatar
Welcome to the site!
So, what were the conditions for you to see the overtemp warning? What were you doing? The "HI" indication isn't an FI alert, it's an overtemp warning. Not good.
First thing to check is to be sure it's actually the fan that isn't working. You need to put 12vDC directly to the fan to see if it activates. Once you know that the fan is working after you bypass everything else, then you can troubleshoot from there.
I don't know what you mean by a "multi-function" relay, since there isn't one. The fan works from a dedicated relay in the relay box, so I'm not sure what you swapped exactly. If you verify the fan is working, the only other things are the relay, the fuse, the ECU, and the temp sensor. One or more of those are bad.
The overtemp warning requires an immediate shutdown to prevent engine damage. There might be other things going on besides the fan depending on when that came on.
#WordCrimes
SkyDork is offline
post #3 of 12 Old 05-07-2018, 09:34 PM
The Pace
scout's Avatar
Fuse. I think we have two fans and both have same fuse. Fans launch about 203f or so.
scout is offline
post #4 of 12 Old 05-08-2018, 06:54 AM Thread Starter
Thank you, I have checked the cooling fan by supplying 12vdc directly and it was working fine as well as the fuse. Planning to send the bike to Kawasaki service center for diagnosis, hopefully they find something on their diagnostic tool.
Still looking into possible loose wire connection somewhere in the cooling system.
post #5 of 12 Old 05-08-2018, 08:08 AM
SkyDork's Avatar
Uh....hmmmm. I would agree with you on that stuff, but then we'd both be wrong.
One fan, one 15A fan fuse, controlled by the ECU set to activate at 95 deg C (203F) and turn off at 90 deg C (194F).
Power to the fan is routed from the fan fuse to the relay. The relay is activated by the ECU. So if the fan is good, the fuse is good, and everything else works, then the issue is likely with the relay (it's inside the relay box). It could also be the wiring in the harness or connectors, but it's not the most likely culprit. The only other thing to verify is that the grounding lug at the frame ground has good contact there. It should be an easy fix.
#WordCrimes
SkyDork is offline
post #6 of 12 Old 05-08-2018, 02:23 PM Thread Starter
Could there be an issue with the ECU? Will an ECU reflash can resolve the problem? Thank you
post #7 of 12 Old 05-08-2018, 03:07 PM
SkyDork's Avatar
It could be an issue with the ECU, but not likely. A reflash could lower the fan turn-on temp, but it won't fix anything related to your issue. Software doesn't fix electrical issues. But if you've had the ECU out or disconnected, there could be a bent pin in the connector to it. That would cause the problem you're having.
#WordCrimes
SkyDork is offline
post #8 of 12 Old 05-08-2018, 07:52 PM
The Pace
scout's Avatar
fan(s) working. what is the temp when you report hot? I'm thinking just a one time digital glitch.
But, under warranty; all good. I'd watch the temp and ride as you report the fans are engaging.
New bikes will do quirks. My new '13 the key would pull out of the gas cap the first few weeks. Then is stopped doing that. The '11 did something stupid at first, too, but can't recall right now.
bottom line: fans work and you have water in the side clear reservoir and temp not near 225f or so, I'd ride.
scout is offline
post #9 of 12 Old 05-08-2018, 07:55 PM
The Pace
scout's Avatar
we have one fan; didn't know as get confused with past bikes. I suspect his problem is not; as in simply a temporary glitch or he's misreading whatever lights. New bikes are a pain to learn.
scout is offline
post #10 of 12 Old 05-09-2018, 09:33 AM
Sneekey10R's Avatar
Send a message via AIM to Sneekey10R Send a message via MSN to Sneekey10R Send a message via Yahoo to Sneekey10R
Seriously....just stop.
Sneekey10R is offline
