Gen 1: 2004-2005 cluster swap - Kawasaki ZX-10R.net
 3Likes
post #1 of 18 Old 06-05-2018, 11:43 PM Thread Starter
king8703's Avatar
Send a message via AIM to king8703 Send a message via Yahoo to king8703
cluster swap
hey will the cluster from the gen 2 fit a gen 1
king8703 is offline
post #2 of 18 Old 06-06-2018, 05:54 AM
I'd like to know as well
Fallguy666 is offline
post #3 of 18 Old 06-06-2018, 06:04 AM
I looked into this before as well, and it seems the short answer is no.
However, there are other options (but it will still cost you over $500 to do.
Use the search though boys, http%3A%2F%2Fwww%2Ezx-10r%2Enet%2Fforum%2Fshowthread%2Ephp%3Ft%3D97087&s hare_tid=97087&share_fid=91412&share_type=t
Sent from my ONEPLUS A3000 using Tapatalk
stokedcrf is offline
post #4 of 18 Old 06-06-2018, 07:25 AM
SkyDork's Avatar
Wow. This topic was covered about 12 years ago. You know, when the Gen 2 first hit the streets in '06 and and everyone still had a Gen 1. Searching is usually the best way to find old information like that.
The answer is yes, it can be swapped, but no it won't plug-in and work. There's rewiring/repinning of the connector to make it all line up properly and you need a custom speedohealer box to convert the speed sensor signal to the newer cluster. If those are even still available. It's not terribly difficult to do if you're motivated and knowledgeable. In most cases it's easier to swap the entire Gen 1 to a Gen 2 model if you like the cluster so much. At least that was the advice given over a decade ago.
fitting gen 2 dash instruments to gen 1 ZX10R
Gen 2 cluster swap on to a Gen 1. Possible? Anyone tried it?
Question 06 cluster on a 04/05?
HOW TO: Retrofit 06-07 Gauge Cluster on 04-05
SpazOnaZX likes this.
#WordCrimes
SkyDork is offline
post #5 of 18 Old 06-06-2018, 09:06 AM
SpazOnaZX's Avatar
I love it.
SpazOnaZX is offline
post #6 of 18 Old 06-06-2018, 10:56 AM Thread Starter
king8703's Avatar
thnx guys
king8703 is offline
post #7 of 18 Old 06-06-2018, 01:01 PM
thundercoupe9's Avatar
thundercoupe9 is offline
post #8 of 18 Old 06-06-2018, 04:00 PM
NinjaLife's Avatar
Originally Posted by thundercoupe9 View Post
https://www.youtube.com/watch?v=H4a-u48UtgU
gen2 gauge
https://www.youtube.com/watch?v=MIuEPg4Ndhk
gen 3 gauge with a working oem gear indicator.
You sell that adapter harness? Or would the OP have to create his own adapter harness?
NinjaLife is offline
post #9 of 18 Old 06-07-2018, 12:12 AM
I don't sell these, it's just an example what can be done if you put your time in it.
NinjaLife likes this.
post #10 of 18 Old 06-07-2018, 07:22 AM
SkyDork's Avatar
gen2 gauge
Good post! Very informative for an age-old question!
#WordCrimes
SkyDork is offline
