Chain Cleaning - Kawasaki ZX-10R.net
 6Likes
post #1 of 14 Old 04-15-2017, 09:20 PM Thread Starter
JepoyDaNinja's Avatar
Chain Cleaning
I have searched around the forums and I did not find any threads about 'chain cleaning'.
Anyways, I just use a chain degreaser, wash it off with water/soap - I repeat this method three times, and then after all that I use a chain lube.
Any method better than mines?
Also, can I just use a WD-40 (cheaper) instead of a chain degreaser specifically being sold for bikes?
Thanks!
JepoyDaNinja is offline
post #2 of 14 Old 04-15-2017, 10:20 PM
Helitech's Avatar
LDH posted a great write up on chain and sprocket AND care
Helitech is offline
post #3 of 14 Old 04-15-2017, 10:58 PM
turtle1000's Avatar
I use degreaser but instead of soap and water I just clean it with a rag. Then use chain wax
More cowbell
turtle1000 is offline
post #4 of 14 Old 04-15-2017, 11:47 PM
Porschenut's Avatar
1 treatment of WD40 gets it sparkling clean.
JepoyDaNinja likes this.
Porschenut is offline
post #5 of 14 Old 04-16-2017, 10:31 PM
TechnologistX's Avatar
Kerosene is a great chain cleaner it will not harm the O-rings and gets the gunk off very easily. Chain wax or most of the main stream lube's will do a good job protecting the sprockets and O-rings. I don't use WD 40.
TechnologistX is offline
post #6 of 14 Old 04-16-2017, 10:38 PM
Victors's Avatar
Wd40 gets in passed the o-rings, you should NOT be using it.
Kerosene to clean and some sort of chain lube that's okay for o-rings.
2013 10R
2007 650R
2016 10R
Victors is offline
post #7 of 14 Old 04-16-2017, 11:08 PM
ZX10's Avatar
If wd40 can get passed the o-rings then shouldn't kerosene do the same and what about using gas instead of kerosene. What about a chain that was never cleaned that you have to figure out? Aren't those o-rings designed to let lube / liquid in but not out so that's just confusing to me, shouldn't de greaser seep in as well?
In my experience the chain stays pretty clean when sprayed from the inside when warm and wipe off the excess from the outside with a rag doused in gas right after. Now something you inherit that was never cleaned is a different story.
ZX10 is offline
post #8 of 14 Old 04-17-2017, 10:17 AM
LDH
LDH's Avatar
Last part of this article is all about chain longevity and the very last area is nothing, but chain cleaning
ROGUE RACING ZX-10R Gearing/Sprockets Page
LDH is offline
post #9 of 14 Old 04-17-2017, 05:43 PM
Helitech's Avatar
^^^there it is! Thanks for posting again LDH
Helitech is offline
post #10 of 14 Old 04-17-2017, 06:55 PM
The Pace
scout's Avatar
I have a dirty loop so do indeed wipe down the chain with wd40. np's at all. This chain is the best: https://www.amazon.com/gp/product/B0...XUD83KN WY8HF
The above chain will last about 18,000 miles if loop has some slab. If no slab then it lasted me around 12-14k miles, if I recall, on same loop. The EK chain is worse than oem and oem is not as good as above DID ZVM whatever. Dealer installed that EK chain and all it did is stretch from the second month. But, if you don't ride much it really doesn't matter. I lightly wiped down all of them with wd40 and I really don't care what NASA uses or thinks about wd40.
scout is offline
Tags
chain cleaning, chain degreaser, chain lube, chain tool
