Bike Acting Wierd!! - Kawasaki ZX-10R.net
post #1 of 3 Old 03-15-2017, 07:11 PM Thread Starter
Bike Acting Wierd!!
Riding my bike Gen4 ZX10 and all off a sudden it just turned off while riding. Got it home and noticed that my bazzaz box wasn't getting power from the power supply which had been wired to the tail light. Found an alternate source to power bazzaz bike ran for just a little bit but turned off again, this time, it started back up but when I went to turn off the bike via the ignition switch the bike would not turn off, had to pull the igniton fuse to turn the bike off? Could these symptoms be caused by faulty ECU, low voltage from battery, or is my ignition switch going bad? Any help is appreciated?
moto1000 is offline
post #2 of 3 Old 03-15-2017, 09:17 PM
The Pace
scout's Avatar
Call bazzaz.
scout is offline
post #3 of 3 Old 03-16-2017, 10:33 AM
belkins's Avatar
Did you just install the bazzaz? I would probably start troubleshooting by removing the bazzaz and go from there. Check connections on battery making sure they are tight. You can also check battery voltage with multi meter.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
