Anyone in Elk Grove / Sacramento area? - Kawasaki
post #1 of 3 Old 08-09-2017, 10:28 PM Thread Starter
Need some help from the local guys if possible to figure out my rear set delima.. Installed Woodcraft rear sets and its stuck in neutral and won't shift up or down. Rocked bike back and forth, its 90 degreed. just don't know what the hell i did.
2016 zx10r abs/krt model. i'll pay for your time guys.
BAY2sacZx10r* is offline
post #2 of 3 Old 08-10-2017, 12:38 AM
Go to daredevil motorsports in sacramento, they're zx-10r experts and should have you fixed in a jiffy.
Address: 4555 Auburn Blvd, Sacramento, CA 95841
Phone: (916) 333-4730
Have you tried starting it before trying to changing gears?
JayBoCC2 is offline
post #3 of 3 Old 08-10-2017, 07:30 AM
SkyDork's Avatar
Welcome to the party!
I'm in Florida, but if you're willing to pay the time I'll come out and fix it with ya. Or you can post a pic of your setup to see if you dorked something obvious up on it.
And since there's a PNF (Positive Neutral Finder) in the transmission, the only gear you should be able to select from neutral is 1st gear unless the rear wheel is spinning. So shifting up or down only applies depending on where you set it up for GP or standard shift patterns. Rocking the bike back and forth does nothing other than setting it up for a drop. There's nothing in the tranny that works like that. You usually have to tip a tranny extra for that kind of behavior. Or so I've heard.
SkyDork is offline
In order to be able to post messages on the Kawasaki forums, you must first register.
