Gen 4: 2011-2015 Adjustable triple clamp question - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By evallarta1
post #1 of 5 Old 10-19-2017, 01:58 PM Thread Starter
I'm considering buying an adjustable triple clamp for my bike over the winter. Has anyone tried different offsets or is the factory 26mm offset the best option for the bike?
desmoninja is offline
post #2 of 5 Old 10-19-2017, 03:35 PM
Carlos76's Avatar
Changed to 30mm offset last winter. Race only. Change was minor. Hard to justify 800e expense. I poor much money to bike, but could have skipped clamps, gen4 turns ok as is.
Bored over the winter: investigate changing to Gen5 frame and reducing the rake>trail with kit head bearings.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #3 of 5 Old 10-19-2017, 05:07 PM
I have adjustable on my new gen4 zx10r. It improved mechanical front end grip, at the cost of some stability but seems worth it for now. As for cost, yeah maybe not the best cost per benefit.
JayBoCC2 is offline
post #4 of 5 Old 10-28-2017, 02:07 PM Thread Starter
This is one bike modification it's hard to find much info about, so thanks Carlos, and JayBo for the input.
post #5 of 5 Old 10-30-2017, 01:20 PM
evallarta1's Avatar
This, like linkages, is a slippery slope if you don't know specifically what you're looking for. In general the ZX10r is long in the front, which makes it very stable in the corners but you have to muscle it to get the bike there. Now you can start adding ride height to the rear but at a certain point you'll have too much swingarm angle which will give you a ill-handling rear end. Another option is to lower the front, but again you sacrifice on other parts. As to you question, yes you can make the bike handle better with triples, but again you have to know what direction you're going.
LDH likes this.
Velocity Calibrations
evallarta1 is offline
